It is currently Tue Oct 17, 2017 7:31 am
PostPosted: Sun Mar 04, 2012 11:12 pm
am i the only one using a Purolater PL30001?
What filter (brand and part #) do you use that IS NOT an oem replacement aftermarket filter?
to keep this easy DO NOT REPLY if the filter you use is already listed
 Post subject: Re: oil filter
PostPosted: Sun Mar 04, 2012 11:24 pm
I like OEM's. They are cheap and my local dealer gives me a deal if I buy a bunch of them at once. :D
PostPosted: Mon Mar 05, 2012 1:02 am
I'm using a pl20195 but that one will be my next one.
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Mon Mar 19, 2012 12:46 am
Purolator but not the stock one since I have an oil filter adapter that for some reason uses one for a DSM engines.
~the other Ralph~
Certified Suzuki Owner:
PostPosted: Wed May 30, 2012 11:09 pm
@ssclown
NAPA Gold one of the best out there
PostPosted: Wed May 30, 2012 11:27 pm
I only use K&N oil filters. For my friends that want cheaper filters I usually recommend STP, Wix, or Purolater filters.
Last edited by 1987TurboSprint on Fri Jun 08, 2012 1:42 pm, edited 1 time in total.
PostPosted: Fri Jun 08, 2012 10:07 am
only purolator and royal purple (going into the new engine)
PostPosted: Fri Jun 08, 2012 10:32 am
Carquest blue 85515 made by wix same as napa gold Great filters and valoline 5w-30 full synthetic
Cars and Harleys
PostPosted: Fri Jun 08, 2012 9:22 pm
For the wife's car and all the dealership vehicles, and all the toys, (Read swifts Metros & sprint) Its either Bosch, or K & N with full synthetic every 3000 miles (Preferably Castrol or Valvoline )(About once a year each) Best wishes, Jonathan
Current stable:
PostPosted: Sat Jun 09, 2012 12:46 am
Senior Member
Many many moons ago there was a post here (or maybe Redline) no... it was here... that extolled the virtues of using a different filter to that prescribed by the manual or any equivalent. The oil filter off of a ford Mustang (V01 filter in my world) has the same thread fitting and seal size but it is an ENORMOUS filter. It adds almost a litre to the capacity of the engine and I suspect, due to its size, means oil can pass through the filter more easily. I have used these for years with no hassles to date.
So, big filter:
more oil
better flow
better cooling..
but the choice is yours....
PostPosted: Thu Jun 28, 2012 7:48 am
@ssclown
NAPA Gold along with Mobile 1 (5w30) I had a lot of varnish in the top end its all gone now
PostPosted: Fri Jun 29, 2012 8:47 am
Forgot to mention that aside from purolator in the swift I use Bosch filters for the Jimny.
~the other Ralph~
PostPosted: Fri Jun 29, 2012 11:50 am
I use the Baldwin B2 oil filter.
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Sun Oct 28, 2012 4:48 pm
motorcraft FL1A works well along with : PH8A, wix 1515
im currently running a EAO15 from amsoil
-91 Swift GTi 1.3 DOHC -wrecked now shell swapping to 1/4 mile car
-90 Metro 3/5 daily driver
PostPosted: Sun Oct 28, 2012 6:29 pm
Fl1a is a purolator 30001
03 cobra bolt ons
