It is currently Sat Oct 21, 2017 10:45 pm
PostPosted: Tue Jul 03, 2012 4:18 am
Senior Member
So, after getting an MLS head gasket, I was trying to figure out how much of a drop in compression this would have on my engine. I chanced upon the following compression calculator
http://www.csgnetwork.com/compcalc.html
I was astounded at how a very small change in the figures made a marked impact on the compression ratio.
f'rinstance, a standard head gasket is .3 mm thick, the MLS is .5 mm
The head gasket bore size of a standard head gasket is 76.5mm, the MLS is 75.3mm
just this difference dropped compression from 11:1 down to 10.68:1
So, to make up the difference, I'll have to shave 7 thou off the head.
Question to anyone with pistons in the hole. what is the piston deck clearance at tdc? Since I totally ripped my engine down, I do not have the liberty to measure this. It would be nice to know how far I can go before I get into interference issues. The guys at the engine reconditioner were talking zero deck clearance for high performance engines.
DOHC G13B (cultus)
Help?
PostPosted: Tue Jul 03, 2012 4:33 am
I think it is zero on a DOHC motor. I've never seen a .3 mm head gasket. Every one I've seen on GT motor is 1 mm thick.
PostPosted: Tue Jul 03, 2012 5:02 pm
Senior Member
Hmmm
<gets out calipers...> dammit, at work, will have to wait... mebbe 1.3??? I know there was .2 difference...
PostPosted: Wed Jul 04, 2012 12:03 am
Senior Member
ellpee wrote:
Hmmm
Mike3 was right standard gasket was 1.3, MLS was 1.5mm
so the boys have taken 3 thou. off the deck. its a compromise.
PostPosted: Mon Jul 09, 2012 4:10 pm
0.003" is barely anything...you'd probably get that off by just passing some sandpaper on it using a straight edge! :P
~the other Ralph~
Certified Suzuki Owner:
PostPosted: Mon Jul 09, 2012 7:43 pm
Senior Member
The compromise was that I had already "passed the sandpaper..." (sheet of glass, valve grinding paste and elbow grease for two hours) to see if I could straighten the kinks out. I will have to see how the pistons are sitting once I get it back.... then calculate exactly how much complression has been lost. I am hoping to get back to a shade under 11:1.
In saying that, it is just a raw calculation. I am unsure exactly how accurate you can analyse true compression even using volumetric displacemenrt with a pipette etc. such a small change in any dimension has quite a marked impact.
