It is currently Wed Feb 21, 2018 8:19 pm
PostPosted: Sun Oct 07, 2012 11:38 am
Since ITB's and EFI is out of my budget, xchipx suggested bike carbs. Since I already have experience with bike carbs on my bike, the swap would be pretty easy, apart from making a new intake manifold. But I didn't find anything on this particular swap and pros and cons of bike carbs vs single carb. Any thoughts?
99 Honda CB600F Hornet
90 Suzuki Swift 1.6 GLX 4WD
PostPosted: Sun Oct 21, 2012 7:20 pm
I say go for it,4 throttle plates close to the head have got to better than 1 further away with differing lenght runners.If you mucked with bike carbs you know jets are cheap so a little time spent should get a decently runnning engine on the cheap-I'd stay with vacuum slides for drivability btw.I'd actually recommend yamaha RX1 sled carbs as they have a side draft design as opposed to the steeper angled downdrafts and will make it much easier to mount,straight shot into the head and the hood will clear.
PostPosted: Thu Sep 10, 2015 8:58 am
Old thread bumping...
I used 1980's-90's Suzuki GS1100/GSX1100 4 carb rack and jet it to your 4 banger as they only cost $100 for the setup and they have Stage 1-3 kits for these too.
Tuning depends on if you plan to run 1 carb per cyl or the 4 carbs feed a common plenum.
1per cyl requires carb syncing but you can tune individually per cyl and make more power and throttle response is higher.
4common fed acts as a large carb feeding a big area where they all draw from, no tuning needed and prob get a some lag but wont be as sensitive.
"If it doesnt fit, use a bigger hammer"
"Cheaper, Faster, Better, Pick Any Two"
http://actfast1234.wix.com/itsmycar
- 89 Daihatsu Charade CLX 1.0L MPFI 3cyl 5spd (*SOLD*)
- 01 VW Beetle GLS 1.8L Turbo (*SOLD*)
- 63 Datsun NL320 Sport Truck 4x4 (Converted by Me & Son)
- 04 GMC Yukon (Fam Hauler)
- 92 Suzuki JR50 (Fun Tiny Dirt Bike)
- 84 Dodge B350 Royal High-Top Van (Heavy Item Hauler)
- 92/94 Geo Metro's (Rebuilt & Sold)
