It is currently Sun Oct 22, 2017 9:30 am
PostPosted: Sat Sep 10, 2011 8:36 pm
I figure this is the best place to post this question.
Has anyone else ever plumbed in an actual set of working Temp and oil pressure guages?
If so, what kind of temps for the coolant did you see?
The reason I ask, I did install working guages on my recent G10 rebuild. The car runs great, the old in dash temp guage usually stays just a hair above the first notch, worst case maybe to half guage. BUT, my working temp guage, with sensor installed into the cylinder head adjacent to the distriutor, shows temps to be 190-195 at avg idle. But extended idle or city driving going up to about 210 before the fan kicks on often going as high as near 220. When the fan comes on it quickly will drop itself back to around 190, but then once again climb. Using a laser temp checker, it confirmed these temps on the guage to be very near to accurate
Entire everything in the cooling loop is new (pump,thermostat,temp sensor for guage) with exception of the radiator. However, radiator was cehmically boiled while off, as well as shows great visual flow when the cap is open, and the fact that the temp drops very quickly when the fan kicks on tells me the radiator is obviously flowing very well.
As very few have probably never installed an actual working guage I have to ask myself if these temps are maybe not just normal operating temps. Worst case I am thinking my fan sensor is just old and kicking in a bit late.
Any feedback appreciated.
Mike
Valley Grande, AL
1986 Sprint plus
Why do we do it?
PostPosted: Sun Sep 11, 2011 9:05 pm
I have installed several aftermaket coolant temp guages and what you describe is rather normal.
The oem thermostat (or at least the ones sold in Canada) opens @ 180f and the fan kicks in at around 200f. The oem coolant temp gauges are crap in my opinion. They have issues with grounding and they have no graduation.
What I found interesting is how hot the engine oil gets. I installed a pan temp sensor and oil pressure gauge and wow. The oil gets as hot as 225f and the resulting pressure drop is worth furling your brow over... That's why I'm installing a thermostatically controlled oil cooler on my next build.
;) :lol:
PostPosted: Sun Sep 11, 2011 10:26 pm
Thanks for the input, and good to hear that another has seem similar ranges. I knew there had to be others out that had upgraded to more reliable guages and had some data.
Its the same here....one can obtain a 195 but I'm running 180
Not a bad idea. I've got oil coolers on all my bigger vehicles. But I dont suppose those temps must harm an engine as my air cooled porsche stays in the 220-240 range all the time. And that is with running a fan assisted oil cooler. Most of the older air cooled ones easily go 2-300k plus without a rebuild, then only usually a top end. On the G10, my oil pressure runs 60-70 at initial cold start, but after warm will run 30 at idle and build to 60 at road speed. Using 10w30, regular dino for a few hundred then full synth.
Mike
Valley Grande, AL
1986 Sprint plus
Why do we do it?
PostPosted: Wed Jul 18, 2012 5:40 am
A big thanks to all for stating such detailed info on it. I was totally unaware of it. I really didn't know much about d temperature ranges. This posting has been a helpful guide for me. I believe d temp mentioned is right for d environment.
PostPosted: Tue Apr 23, 2013 9:07 am
I also wanted to thank for that info. I thought my car was overheating and that scared me everytime I used my a/c and was stuck on traffic.
Some pics by the way, just to brigthen the mood of the thread. My mod is based on the fact that here we don't use or have the heater option on the Swift, but the hose that goes from the intake to the lower hose piping of the radiator is still there. So, why not plug a temperature probe there, as you can see, poor man's option, and yes, that's gas piping I used.
And yes, for the automatic you kinda have to modify the stock rad a little (quite more like a right handed modification)
And before all that, pretty close to the fender is the tranny cooler. Bypassing the radiator of course.
Suzuki Swift GLX - 1.6L - SOCH 16 valves - Carb Model
Mods: Auto Tranny Cooler
Weber 32/36 kit from Toyota Tercel
2 row aluminiun radiator
