It is currently Sat Feb 24, 2018 11:12 am
PostPosted: Sun Dec 27, 2015 4:03 pm
Replaced a brokin timing bekt. Now having valve noise. Sounds like a disel during mediun to hard accelleration. Idle is fine, MPG same, no drivability issues. :?:
If your using more than 3 cylinders your just wasting gas.
I spit on hybrids at stop lights.
PostPosted: Sun Dec 27, 2015 4:28 pm
One tooth advanced maybe
PostPosted: Mon Dec 28, 2015 6:37 am
which car/engine??
if it's gti you would already bent valves by 1 tooth advanced/retarded... dunno for other swift engines..
PostPosted: Mon Dec 28, 2015 9:27 am
I've slipped a tooth on a stock gti with no damage :huh:
___________________
89 Swift gti
PostPosted: Mon Dec 28, 2015 9:47 am
Its a 3 cylinder - 90 Vert. I have Friday off and will take a second look at it. Thanks All.
PostPosted: Mon Dec 28, 2015 1:47 pm
Same, I slipped one tooth on my cultus engine and no damage.
PostPosted: Tue Dec 29, 2015 12:43 pm
hmm.. gti have 18 degree per per cam tooth.. and i was told that at 15 degree valves hit piston.. if stock gti "survive" 1 tooth slip then that's even better!
PostPosted: Tue Dec 29, 2015 7:50 pm
pretty sure i slipped two even!
___________________
89 Swift gti
PostPosted: Thu Dec 31, 2015 4:05 pm
Pulled the cover this moring. Marks look good, see pics
PostPosted: Thu Dec 31, 2015 10:22 pm
loose crank bolt hogged out crank key
PostPosted: Sun Jan 03, 2016 4:37 pm
Remove the belt and check for wobble @ crank pulley. Also see if you have any wobble/play in cam pulley. If you got a lot of play in the crank pulley its either crank pulley bolts or timing key issue. I had a key brake on me awhile back. Not cool.
PostPosted: Sun Jan 03, 2016 9:27 pm
Tightened the timing belt and put it back together. Went to double check the timming, pulled the vacuum lines off the distributor, found the screw that holds the vacume can to the dizzy missing. :huh: Guess that little screw kinda important. Set at 6deg btdc , locked her down, no noise! Thanks all for the help.
PostPosted: Sun Jan 03, 2016 9:54 pm
Run it up to 10-14 for better performance. You shouldn't experience any ping at those numbers
