http://www.teamswift.net/
I need some measurements off a G13.
http://www.teamswift.net/viewtopic.php?f=11&t=61711
Page 1 of 1
Author:  makenzie71 [ Wed Jun 01, 2016 11:08 pm ]
Post subject:  I need some measurements off a G13.
I'm looking for an engine to swap into my Roketa GK34. This buggy originally came with a Suzuki F8B, but it's worn some oil rings and valve seals and it's just not got enough oomph for my buggy. Time to upgrade.
My prospective engines are a G10/5 speed from a '96 Metro or a SOHC 16v G13BB. The G10 is close, dimensionally, to the F8B, and it's a fairly simple engine so swapping it in won't be too much trouble.
The G13BB is more interesting because of the 25 extra horsepower and because it has an automatic transmission...not everyone's favorite, but I like crawling over rocks and I'm hoping that making it easier to drive will gain my wife's interest. My problem here is I'm not sure the engine will fit between my shocks and keep the differential spool centered (I would like to keep equal length axles). That's the measurement I really need...
If I were to center my differential spool (again, equal axle lengths), how much room do I need off to the side to fit the motor?
Author:  suzukitom [ Thu Jun 02, 2016 1:48 am ]
Post subject:  Re: I need some measurements off a G13.
While waiting for an expert here to respond with dimensions for a G13BB with automatic, you might want to also try some other custom build sites that use Suzuki engines:
http://www.homebuiltairplanes.com/forums/geo-suzuki/1634-suzuki-specs.html
Author:  makenzie71 [ Thu Jun 02, 2016 5:14 am ]
Would that "1300GS" mean the G13? I'll sign up over there and ask the same. Thanks!
http://www.phpbb.com/
