It is currently Tue Jan 16, 2018 6:38 pm
PostPosted: Mon Mar 07, 2005 10:13 am
I did a search and saw one other thread over a year ago about this subject. I thought I would show what I did to make a Mk2 GTi steering wheel work on a Mk3 Geo Metro and work with the turn signals.
As was stated in a previous post, the Mk2 steering wheel uses two small roll pins on the back of the wheel's hub to cancel the turn signal switch when turning. The Mk3 uses a plastic colar on the column that has two small pins that lock into two small holes in the back of the steering wheel hub.
I thought at first I could just remove the pins and I would be in business but the holes are closer to the center on the Mk2 steering wheel and do not line up with the pins in the colar of the Mk3.
So, I modified the back of the GTi steering wheel by making slots in the hub with a die grinder to allow the collar to lock into the hub of the Mk2 wheel. It works out great, and the holes are still there to insert the pins back so it can still be used on the Mk2.
M3----"M" body "3" cylinders.
Now Turbo'd
"M3 like the BMW?"
PostPosted: Thu Mar 10, 2005 1:46 am
you helped me out without you know it :lol:
I have also a GTI MK2 steering laying down here, cause it didn't fit... but you brought me a wonderfull idea to try it again :) thanks alot. I will try it soon and post the pics ;)
PostPosted: Sat Mar 12, 2005 4:20 am
here is my MK2 GTI steering wheel on a MK3 :)
PostPosted: Sat Mar 12, 2005 12:08 pm
Thanks for the 'How To' M3 ! :D
Took all of ten minutes. I used a air cutt off tool to make the slots. The metal is not hard so practically anything will cut the required notches.
PostPosted: Wed Jul 03, 2013 4:48 pm
can somebody please repost some pictures of this? the links are no longer working and this would really help me! thanks
PostPosted: Wed Jul 03, 2013 7:46 pm
those links died 3 server moves ago. i'd bet they cannot be recovered. :blackeye:
PostPosted: Wed Jul 03, 2013 8:31 pm
Do you happen to have any pics of this mod?
cron
