It is currently Tue Jan 16, 2018 8:10 am
 Post subject: gutted
PostPosted: Mon Aug 08, 2005 7:13 am
Stripped out the inside of swifty last night> took all of about 45 min. I dont want to see all that nasty wieght going back in there. So heres what I'm thinkin. Anybody ever use hippo linner for there interior? My brother in law just finnished putting it on the floor of his pickup, stuff looks amazing ,is said to be durable and here's the biggie LIGHTWEIGHT!!!! let me know what you think still have a small hole in the floor to fix and some of that tarpaddin crap to get out. But for 50 buck I think this is the way I'm going to go. Cover the whole floor front to back no carpet. the plastic door kicker moulding is only going back in so i can hide power and RCA cables ebrake wire to be relocated under console and those plugs under the seats that dont go to anything NEON cuz my wife hates it :twisted: :twisted: hehehehahahaha! keep you posted
PostPosted: Mon Aug 08, 2005 7:45 am
I used the indoor/outdoor carpet from Home depot. It comes in a few different colors, looks pretty good, is easy to work with, and weighs almost nothing.
http://www.teamswift.net/3tech/images/M ... g1_reg.jpg
PostPosted: Mon Aug 08, 2005 9:43 pm
I left mine empty: :mrgreen:
PostPosted: Mon Aug 08, 2005 9:51 pm
Man you should see my car now. Pics will be up next weekend.
I drive 30K miles a year in a gutted car. I don't think there is anything else I can take out. I even stripped down the wiring harness to the bare essentials.
Next will be the undercoating. Kerosene, right Mike?
Not very fast, but fun.
PostPosted: Tue Aug 09, 2005 4:41 am
I'm curious to see pics of gutted cars. I'm doing the same to my Swift when i get back to the states. I think i'm going to leave the 2 front seats and thats it. But i still want it to look clean.
ccRacer
PostPosted: Tue Aug 09, 2005 4:42 am
If its that tar stuff, kerosene works great. The sound deadener needs some heat, though.
PostPosted: Tue Aug 09, 2005 7:21 am
i have mine gutted, i have got back to the metal through-out the car and have just used some black paint to tidy it up.
to match i got the white cage and black buckets. i would never put anything back in, so nice with out it all. (plus i scrapped the interior)
PostPosted: Wed Aug 10, 2005 1:36 pm
ccRacer
Here's what I did to mine:
http://www.teamswift.net/album_personal ... er_id=1972
I'm currently busy putting Aluminium sheet on the sides to cover those ugly holes and I also found a "NOS bottle look alike aluminium "thank" " which I'm currently busy modifiyng to turn it into a fuel thank which will go into the spare tire compartment. Pics of these will come up soon.
I'm also thinking of getting the dashboard out to remove the metal thing that goes side to side under the dashboard, and right in the middle it kind of opens out. Anyone know if this thing is bolted or welded to the body?
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Wed Aug 10, 2005 2:05 pm
I believe that it is bolted
PostPosted: Wed Aug 10, 2005 10:04 pm
Are you talking about the crossbar? If you take that out the sterring wheel will not be mounted anymore.
PostPosted: Thu Aug 11, 2005 4:17 am
The MK3 has some vertical support braces in the middle of the dash that make it a nightmare to remove. The horizontal brace is different is different from the MK2, in that it splits into two around the stereo area. Both MK2 and MK3 horizontal braces are screwed to the frame of the vehicle with four large Phillips head screws. Some people have found these rusted on. I'd recommend using a Phillips driver on a ratchet handle or an impact gun, the first time you remove them.
There's a separate tubular brace for the steering column above the ECU, this is also bolted in. The steering colum itself is primarily secured to a large box structure spot welded to the firewall. You could probably remove the tubular brace without effecting the steering.
PostPosted: Thu Aug 11, 2005 7:15 am
Thanks Lithan, I will try that when the time comes.
2003-EVO7 GT-A
PostPosted: Wed Aug 17, 2005 12:08 am
Drivers side view
PostPosted: Wed Aug 17, 2005 12:09 am
Passengers side view.
PostPosted: Wed Aug 17, 2005 12:12 am
Towards the back. It now has a harness bar and a triangulated rear strut tower brace that is welded in with load plates. Load plate are welded in before the tubing to strengthen the sheet metal.
PostPosted: Wed Aug 17, 2005 11:17 am
You forgot to remove your stereo. :poke:
PostPosted: Wed Aug 17, 2005 9:30 pm
Yeah, what the heck is the point of that? Can you even hear it over the sound of wind, tires, gravel, rain, etc?
"The early bird gets the worm.....and usually works for someone who comes in late and owns the worm farm!" - My Boss
PostPosted: Wed Aug 17, 2005 11:35 pm
I still drive around 30K miles a year in this car. I like the radio, it helps me keep my sanity. I think I may remove the pair of speakers from the front and put the rear ones up front.
My car stereo plays the soundtrack to my life.
PostPosted: Thu Aug 18, 2005 12:54 am
I have to admit that even I have recently gotten temped with car audio...
I now use a Discman and headphones on long freeway trips :mrgreen:
PostPosted: Thu Aug 18, 2005 1:50 am
First thing I REMOVED on my car.
But then an N/A 3 cyl. needs all the help it can get :-P
PostPosted: Thu Aug 18, 2005 2:45 am
Does anybody ever get any questions from other motorists about the absence of any interior? It seems that I can't leave a parking lot without someone saying
"Hey you're missing a dash!"
"You sure got a lot of room in that thing!"
"When are you putting the car back together?"
"Do you race that?"
"Did you do that for fuel economy?"
"Did you do that for speed?"
PostPosted: Thu Aug 18, 2005 8:50 am
I think the biggest question is "what do you answer to them?" :wink:
GeoZukiGTi wrote:
CJDavE wrote:
Chassis Flex Motorsports
PostPosted: Thu Aug 18, 2005 3:39 pm
You missed some stuff.
1993 Metro XFI w/ Turbo Buick V6
9.27 @ 154
1992 Metro daily driver
PostPosted: Thu Aug 18, 2005 4:41 pm
:shock: nice chassis... hmm look like truck frame but i like it
sorry bout my bad english
PostPosted: Thu Aug 18, 2005 10:40 pm
Cheater. I've been tempted to something similar but with an STS Northstar motor and trans in the back. Since the Caddy motor overhangs to the front I think the weight balance will be nice.
Anyone have a MKI less motor?
