It is currently Thu Jan 18, 2018 5:36 am
PostPosted: Tue Feb 25, 2003 12:40 am
A legend in his own mind
Hey guys,<br><br>my '89 SSGTi never came with the Overhead Dome Light/Clock combo; it only has a typical Dome Light.<br><br>I was wondering if anyone elses car didn't have the Clock combo and they went ahead and did the "conversion" so to speak...<br>Did you have to run new wires, or was everything there already?<br><br>Thanks in advance guys,<br>Tommy <p></p><i></i>
PostPosted: Tue Feb 25, 2003 1:15 am
i've only got the normal one myself, but ray/ssgt92 says the clock version just plugs right in =) it's up there on my list of things to do ..<br>his advice has been flawless w/ pulling apart my interior to upgrade the stereo =) which turns out to be super simple on these cars, but i need to find a dozen replacement clips or so now <!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Tue Feb 25, 2003 2:17 am
Senior Swift Guru
I think Gticouple has an extra clock or so, if you want to get in touch with them, let me know. <p>-Kyle Jones <!--EZCODE LINK START--><a href="http://www.angelfire.com/de/ksj/myswift.html"><br><!--EZCODE BOLD START--><strong> Junk-Yard Turbo set-up, formerly NOS-fed, constantly evolving 1989 Suzuki Swift GTi</strong><!--EZCODE BOLD END--><br></a><!--EZCODE LINK END--><br></p><i></i>
 Post subject: Make sure you get.
PostPosted: Tue Feb 25, 2003 9:44 am
You need the harness with it. Once you have that and the clock. It is plug and play for 89 to 94. <p></p><i></i>
 Post subject: done this one :)
PostPosted: Fri Feb 28, 2003 7:56 am
I have a standard swift no clock of course <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> got one, thought plug n play = yes/no.<br>The wiring in the swift is there but the plug is located at the bottom of the a pillar on the passenger side, so of course had to run wiring up the a pillar to the clock mount <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>Another thing i encountered with it which is deceiving if u dont have the wiring harness, is that one of the clocks wires must be grounded near the dome light the other 4? run down the a pillar into the stock wiring <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>good luck! <!--EZCODE EMOTICON START 0] --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/alien.gif ALT="0]"><!--EZCODE EMOTICON END--> <p></p><i></i>
 Post subject: Re: done this one :)
PostPosted: Mon Mar 03, 2003 10:35 pm
Anyone got a pic id like 2 see one thanks.<br>George <p></p><i></i>
PostPosted: Mon Mar 03, 2003 10:52 pm
Me too on the pic!<!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> Thanks.<br>Derek <p></p><i></i>
 Post subject: pic?
PostPosted: Tue Mar 04, 2003 12:26 am
Its just the clock in the center of the light housing? <p></p><i></i>
PostPosted: Fri Jun 28, 2013 8:56 am
Pic:
I doubt my '94 Metro has the harness in the lower pillar, so I will be scouting wiring info to make my own.
'94 Metro LSi 'Green Machine'
'94 RHD (Totaled)
Vail, AZ
PostPosted: Fri Jun 28, 2013 2:01 pm
the harness is by the radio, you can fish a peice of wire through the pillar on the right side without taking apart the headliner
08 Civic Wife's car
PostPosted: Mon Mar 24, 2014 12:37 am
Gonna dig this up. What kind of light bulb does it take for the clock?
Btw there is a plug on the pass side kick panel for the clock on the mkII's for the peeps that don't know, you just need the harness.
Formally "Allmtrswft".
Someone is always going to have a faster Swift, so why molest a clean one? It can be new only once!!!
1991 Suzuki Swift GT. Featured in "Modified Magazine" and will squeeze a 14.9 1/4 mile pass out of her.
1994 Suzuki Swift GT.
My car is a trailer queen 'cause it's too slow to merge safely into traffic.
PostPosted: Thu May 08, 2014 4:38 pm
Are you sure it is just the lightbulb that is bad? Can you see the numbers if you illuminate it yourself?
89 Suzuki Swift GTI
15" Lancer OZ Racing Rims
Custom Trailing Arms by Dethbrd
Boxed Rear Control Arms
Super Pro Poly Bushings
Genie Header
Nissan Intake Manifold
2 1/4" Exhaust
Turbine Tech Underbody Brace
Honda CRX Front Brake Calipers
