It is currently Thu Jan 18, 2018 1:07 am
 Post subject: Side mirrors
PostPosted: Fri Mar 23, 2012 1:25 pm
@ssclown
I just wanted to share this with you guys I have not used these but I did see on here someone found these to be a direct replacement.I think i might get one and see if it does infact fit and fit well
http://www.discountbodyparts.com/catalo ... d=pgrabber
 Post subject: Re: Side mirrors
PostPosted: Fri Mar 23, 2012 1:54 pm
I also read somewhere on this site that the B2200 mirrors were a direct bolt on for the MK1, but I thought they were talking about similar years.
Maybe these are the same, but if you are going to buy, check and see if the are the same part number as the 87 B2200.
One advantage was the swing action, IIRC.
PostPosted: Sat Mar 24, 2012 9:35 am
@ssclown
Yep!!
http://www.discountbodyparts.com/catalo ... azda+B2200
PostPosted: Sat Mar 24, 2012 1:00 pm
MA-14
Yeah, they're the same, so you should be good to go.
For $13.40 black or $11.77 you'll get a mirror that should bolt right up and you'll have the option to fold it.
BTW, if you get into a bind, the heater blower motor resistors on the Mazda will swap in to the Chevrolet Sprint with little or no modification to the resistor casing.
(Shhh...don't tell my vapor trail... :shock: )
PostPosted: Mon Apr 16, 2012 1:06 am
I tried to cover mine with 3M di-noc CF vinyl, but I don’t like the look....I think clear coating them spoiled it for me.
I’m now looking to replace them with some F1 styled mirrors for the minimalist look, but all I can find of good quality are the TC Motorsports one.....a bit pricey at $164.00 though!
~the other Ralph~
Certified Suzuki Owner:
PostPosted: Mon Apr 16, 2012 2:23 pm
With pics :D
viewtopic.php?f=12&t=49736
'87 Chevrolet Sprint Turbo
'89 Suzuki Swift GTi 16v 1.3L DOHC - Sold
PostPosted: Thu Apr 26, 2012 7:14 pm
Does anyone know if the swift window regulators(mk3) are the same for 4 door hatches and sedans?
PostPosted: Wed May 16, 2012 1:10 pm
Update: I thought the TC Sportlines were expensive but check out these:
http://www.nengun.com/craft-square/
:shock:
~the other Ralph~
PostPosted: Sat May 19, 2012 10:15 pm
:shock:
You can get a very similar look with motorcycle (sportbikes) mirrors very cheap...
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Mon May 21, 2012 12:34 pm
:shock:
Yeah but I think the cost of the craft square ones are because they are authentic carbon fiber ones made with blue glass.
~the other Ralph~
PostPosted: Fri Jul 27, 2012 1:19 pm
Do you guys know if the Spoon Mirrors will fit in a SS GTI 94 ?
http://www.google.com/imgres?q=spoon+mi ... s:28,i:171
PostPosted: Sun Jul 29, 2012 10:08 pm
Do they have an application chart? If not, maybe you can send them an email to enquire.
~the other Ralph~
PostPosted: Tue Nov 06, 2012 12:39 pm
Hi all Side mirror is the helpful for you and another driver and side mirror are protect you you can see the back side who come from your left or right side.I’m now looking to replace them with some F1 styled mirrors for the minimalist look, but all I can find of good quality are the TC Motorsports one
Toyota prado lift kit
