It is currently Sat Nov 18, 2017 7:26 am
PostPosted: Fri Jul 06, 2012 1:41 am
Hey guys recently i found myself needing to do an upgrade to my Geo's cluster and well i did.. and it looks mighty Fine!!! If you are serious about getting this done PM me or leave me a message in here, If you want Information how to do this properly yourself don't hesitate to ask, Those are also not the factory Bulbs they are LED's. Thanks Guys!! I am Based in Pennsylvania. If you do want my services we will discuss a price at the time the matter occurs.
NOTE: I did not mess up the White Faces in the pictures Below the x1000 RPM was for some reason replaced and moved up with Unleaded Fuel Only by the people who created White face gauges... I still am Unsure why but the faces are otherwise perfect, Thanks. My geo's cluster does not have this so if yours does rest assure it will be perfect. I will also offer Needle painting services
White Face Gauges Install:
Lighting After Installation In the Day-Light:
Lighting at Night While Driving:
1995 Geo Metro Hatchback **1.3L DOHC 16V Gti 94 Engine**
PostPosted: Mon Jul 09, 2012 2:10 pm
This is really nice, I live 20mins from pittsbrugh are u anywhere close ??
But I have a couple of questions, how hard is it to change thos LEDs behid the dash ??? Cuz Id really like to change them to red with your white Gage's
Do u already have Gageclusters?? If not I can pick them up
Is it possible to get the Gage's you have in your car .i have a 2000metro lis an it don't a rpm gage...
2000 metro L"Si":)
2001 suzuki swift
PostPosted: Mon Jul 09, 2012 9:49 pm
I live in Downingtown Pennsylvania, and I do not have any clusters for sale and the white gauges i have are available at whitegauges.net, The leds in the back are very easy to do once you got the cluster out.. anybody can do it.. Needle painting and white gauges however take much patience which is why im offering the service because im a very patient person, in order for you to get a tacometer you would need to buy another cluster off ebay or something.
PostPosted: Tue Jul 10, 2012 6:16 pm
my stock gauge cluster with red led backlighting.
pulling the cluster, cleaning, replacing the bulbs, and re-installing the cluster takes under an hour. you have to check each led to make sure you have the polarity right so they light up which means that you might have to plug them in twice to get them right.
also, a heads up for you - you have to use inverted lens leds (vs. the typical domed, focused leds) as there are lucite light spreaders surrounding the lamps that carry the light to the numerals and pointers. the focused beam leds do not function well.
you'll need 194 style lamps for the face and pointer illumination and 74 style for the annunciator lamps. don't waste your time trying to use leds for the high beam and turn indicator lamp positions. incandecent bulbs work best in those spots as the blue and green filters require very bright lighting.
PostPosted: Wed Jul 11, 2012 6:15 am
Great work, it looks brilliant :)
http://www.ecoledlight.co.uk/
PostPosted: Thu Jul 12, 2012 8:44 am
I only use LEDS for the big Bulbs... Work way better than stock ones 360 Leds brightness can't be matched, Also Bulbs r easy... White faces take some practice.
