It is currently Fri Jan 19, 2018 5:04 am
PostPosted: Wed Sep 19, 2012 7:53 pm
Hello all,
I was trying to adjust my beams up and down....
the adjusting screws through the back don't seem to adjust anything
Are these headlights finicky?
___________________
89 Swift gti
PostPosted: Fri Sep 21, 2012 5:28 pm
the glass headlight adjusters move the reflectors inside the housings. you should be able to see them move through the lenses with the lights off.
some of those glass composites are for right hand drive cars so they act differently from the left hand drive lights. they don't have as much adjustment to the right. are you sure that you haven't reached the limits of their adjustment?
