It is currently Mon Feb 19, 2018 4:52 pm
PostPosted: Sat Oct 27, 2012 9:01 am
Having headlight issues. A. won't always come on - will have to try the button two to three times. B. Wiggle the button and they will go on/off. C. If I switch to just parking light they wont always go off. What dose the doctor(s) think? Also cant figure out where the headlight relay is located. Is it the thing rapped in black rubber hanging off the front of the fuse box in the engine bay?
If your using more than 3 cylinders your just wasting gas.
I spit on hybrids at stop lights.
PostPosted: Sun Oct 28, 2012 2:04 pm
there are no headlight relays involved. the fsm electrical diagram for model year 91 shows the piano key switch and the hi/lo beam selector switch with individual 10 amp fuses on each headlight.
remove, clean, and re-insert the headlight lamp connectors. check the connectors and the fuse panel under the dash for corroded and/or connectors or copper traces. check the connector under the instrument pod for the light switch assembly, unplug it and plug it back together (the connectors are supposedly self cleaning.)
