It is currently Thu Feb 22, 2018 11:56 am
PostPosted: Sun Apr 13, 2014 8:07 pm
Hey everybody just wanted to do a little write up on how to install clear corners. This will work on any swift/metro and i believe firefly and sprint from 89 to 94 with plastic headlights enjoy. thanks
File comment: Headlight bracket.
File comment: First cut that off
File comment: then cut there
File comment: better view of the last cut
File comment: last cut there
File comment: now before you mount the headlight use a hammer to flatten this lip.
File comment: on the clear corner bracket cut and bend it back like the picture. p.s when installing the clear corner you might have to play around with this bracket.
File comment: now reinstall the headlight. once again use your hammer to bend back this corner.
File comment: install the clear corner and your done.
PostPosted: Sun Apr 13, 2014 10:21 pm
that seems a lot more involved than the depo ones I installed in my metro.....I know I bent that bracket back, but I cant remember cutting anything else out......Its been awhile since I installed mine, (4x6 glass hid) i would have to go check.
GOOD WRITE-UP. GOOD PICS.
NICE UPGRADE,ISNT IT? 8)
never mind,i did cut out the same amount of bracing behind the lens........ still worth it.
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
