It is currently Sat Feb 17, 2018 4:53 pm
 Post subject: Un-Facelift?
PostPosted: Wed Mar 18, 2015 4:08 pm
Hello,
Just wondering can you un-facelift Suzuki Swift Mk3's?
I prefer the front and rear bumper and light assemblies on the Mk2 and was just curious is it as simple as bolting on new wings, bonnet, lights and bumpers?
Thanks
Billy
 Post subject: Re: Un-Facelift?
PostPosted: Wed Apr 15, 2015 1:44 pm
I'm not sure from which to which look you want to go. I think, since you mention changing the bonnet, that by mk3 you mean the model with the bigger headlights and the rear bumperpiece extending up to the hatch.
Headlights, bonnet and bumpers are a bolt-on, rear lights too, although . I'm not 100 percent certain about the center light assembly, there needs to be a bracket for it. I believe the mk3 rear upper bumper doesn't use it, but it still might be there. I did an un-facelift to the even older rear lights and bumpers and I had to remove that bracket.
'95 Swift 1.0:
- 0,5mm oversized pistons
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- TBI bridge removed
- srd underdrive pulley
- GTi catback
- deleted cat, now 2" ss pipe
- 14x6J ET45 BSA Racing
- Nankang AS-1 165/55-14
- GTi sway bar
- Turbinetech underbody brace
0-100kph: unknown seconds
