It is currently Fri Jan 19, 2018 3:24 pm
PostPosted: Sun Aug 30, 2015 8:57 am
My suzuki swift doesn't have cruise control installed, it also has manual A/C, is it possible to buy the cruise control like the link below and automatic climate control and install them?
Thanks in advance.
Genuine Suzuki Swift Sz3 Sz4 Steering Wheel Audio Cruise Switch Control | eBay
PostPosted: Tue Sep 01, 2015 8:59 am
Rostra makes several different universal aftermarket cruise control kits.
I went with the wireless remote steering wheel unit.
I have had mine installed and working for over a year.
Some minor tuning with there tech support getting the settings right.
After the tuning the cruise control works flawlessly.
A couple of helpful hints:
Mount the servo in the engine compartment. I was able to mount mine to the fire wall.
They want you to hook up the control cable to the gas pedal. I made new mounting brackets and connected mine to the
throttle body.
If you have a 5 speed standard, make sure to connect the tach wire and the clutch switch.
http://www.ebay.com/itm/Rostra-250-1223 ... 3cc40a8efe
Fainya
