It is currently Fri Jan 19, 2018 5:21 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jul 16, 2006 10:10 am
I am guessing the car had bad rings. The oil dip-stick has a way of coming up and spraying all of the crankcase oil out of the tube. Sounds strange, but that's the way it happened.
Do you have pics of your 12" subs?
Not very fast, but fun.
PostPosted: Sun Jul 16, 2006 4:13 pm
a pair (although I've only finished one) of horn loaded 12inch Pioneer subwoofers :)
PostPosted: Fri Jul 21, 2006 5:44 pm
PostPosted: Fri Jul 21, 2006 5:45 pm
there is going to be a window infront of the woofer, on the front of the box, so you can see the cone.. :)
PostPosted: Tue Nov 28, 2006 2:36 am
I finally built one and put it into my Scion. It works very well for an 8" with less than 100 watts. It has a very tight quick sound to it.
The next project is a single driver rear loaded horn system with a cheap 4 1/2" pioneer. I will likely switch to a Fostex before too long.
