It is currently Fri Feb 23, 2018 3:30 pm
 Post subject: removal of stock radio
PostPosted: Tue May 02, 2006 12:16 pm
does anyone know how to remove the stock radio from an mk2 swift. ive searched but only found topics about mk3 swifts. please help before i rip it out! :twisted:
EngineWhisperer wrote:
v-tec ain't $hit honda sucks and b16-18 are like tampons every pu$$y needs one.
PostPosted: Tue May 02, 2006 12:40 pm
Remove the HVAC knobbies....take out radio/hvac bezel screws...once bezel is out, radio brackets should be held in with some phillips screws...
If you ask why, you don't get it.
If you ask how, you get it.
PostPosted: Tue May 02, 2006 12:57 pm
thats my problem the knobs wont come off and the heater controls are behind the bezel not apart of it, i managed to get the bottom part of the bezel off but the top where the radio is wont come loose. am i missing a screw or something? i even removed part of the center console thinking there was a screw there.
PostPosted: Tue May 02, 2006 1:54 pm
I checked Alldata, they say that on a '91 Metro, there is a bolt at the back of the radio, and you need radio removal forks that fit into either side of the face plate...but I don't know if that applies to the Swift as well...
PostPosted: Tue May 02, 2006 8:24 pm
thanks. ill try that
PostPosted: Fri May 05, 2006 12:37 am
well, i got the stock radio out and the new one in. it turned out theres a screw on each side of the radio! what a pain in the ass that was. :x
PostPosted: Thu Jun 12, 2008 9:01 pm
I can't figure out how to remove my stock radio at all. I dont see anything that holds the bezel on. I'm clueless! I bought a factory manual and its not help. Manuals directions say "Remove Radio". Great how the hell do I do that!
What install kit did you buy to install the new radio? I'm very frustrated even my old 86 truck was much simpler, and they actualy made an install kit for it!
