It is currently Tue Jan 16, 2018 10:52 am
 Post subject: Amp Problems
PostPosted: Fri Oct 20, 2006 9:37 am
Ive had my amp and subs for about 2 years, i have one amp powering 2 woofers. Today on driving home my amp just suddenly cut out. Now it just turns on for one beat then turns off for a few seconds and then turns back on. I can tell this from the power LED light. The one beat only comes out of one of the 2 woofers i have, the other woofer lays dorment.
Ive checked all the connection on the amp and they seem fine. And i have checked the connections from the head unit to the amp and they seem fine aswell. Also all the fuses on the amp and power cable look fine.
Do you think my amp needs replacing or do you think that i need to check every inch of wiring as the problem probably lies there?
Many thanks in advance
Ichiban
PostPosted: Fri Oct 20, 2006 10:22 am
I'd check the grounding. It may only be getting ground through the shield braiding on one of your audio cables.
PostPosted: Fri Oct 20, 2006 4:22 pm
What he said and check the impedance of the enclosure. You may have a shorted sub since its only one of them playing.
PostPosted: Sun Oct 22, 2006 11:04 am
Thanks for the advice, i checked the ground cable and it seems fine, i also checked all the cables but they seem fine too, i am however yet to check them all with a multimetre.
However when i originally found the amp was not working i noticed that the phono cables had come out the front of the amp and most probably will have touched whilst the stereos been on. Is this likely to have done some damage? Blown something in my headunit?
I took out the phono cables (and nothing else) and ran my system and it was running exaclty like it was when they were plugged in (same problem of the amp turning on and off).
What do you think? Do you think the problem may lie with the amp or the headunit?
Many thanks in advance!
Ichiban
PostPosted: Sun Oct 22, 2006 4:32 pm
Check the impedance of the subs hooked up to it. If that is OK try running a constant power source from the battery to the remote on. If the problem clears up its your remote wire.
PostPosted: Wed Oct 25, 2006 1:08 am
If you have a car stereo shop nearby, pull it out and have them bench check it for you. My shop does this for like 10 bucks.
PostPosted: Sun Oct 29, 2006 12:04 pm
Just thought id follow up for anyone that was interested... basically i checked everything, and followed all your suggestions. In the end I bought a new amp and my system works fine.
So basically my amp gave up on life lol
Thanks to everyone that offered advise.
Ichiban
PostPosted: Fri Nov 03, 2006 6:59 pm
mind if i ask......what kind of amp was it that you had before your new one?
