It is currently Fri Feb 23, 2018 3:34 am
 Post subject: amp dead?
PostPosted: Wed Nov 15, 2006 11:14 pm
So I hooked up my system and this happens: a loud hum and both 30 amp fuses blow on the amp. Keep in mind that the system was already wired from when I took it out and everything worked fine then. So I replaced the fuses and now the amp turns on fine, but their is no sound whatsoever. I tried different audio cables and nothing. I tried a differant sub, nothing. So is it fried and why? Thanks, BTW its a kenwood 800 bridged to two audiobahns.
PostPosted: Sat Nov 25, 2006 2:28 am
are you sure the preouts on your deck are working still?
PostPosted: Sat Nov 25, 2006 11:51 am
Yeah check the preouts and then check the impedance that the subs are wired to. Might have to low an ohm load for the amp.
