It is currently Mon Feb 19, 2018 5:31 am
 Post subject: cd player fault
PostPosted: Thu Dec 28, 2006 3:00 pm
for some reason when i turn off my car and the next day start my swift the cd player does not come back on automatically nor does it save the radio stations anymore what could be the cause of this? faulty ground? because when i turn the ket to ACC the cd player turn on automatically and the radio stations are saved but now it doesnt.
PostPosted: Thu Dec 28, 2006 3:56 pm
The memory wire of your CD player isn't on a constant power source.
PostPosted: Thu Dec 28, 2006 6:44 pm
the memory wire is normaly be which wire? the big posotive wire? and does that wire connect to the 12v ignition switch wire?
PostPosted: Thu Dec 28, 2006 8:07 pm
What brand of cd player is it? you will have two power wires, the smaller one will be constantly on and the bigger will only be on with the ignition. There may also be fuses on each of those wires, if there is check that they are both good.
Scott
Its not lag, its suspense...
1987 mk1 T3
PostPosted: Thu Dec 28, 2006 10:45 pm
Usualy yellow with a fuse on it. Your CD player may be different.
PostPosted: Fri Dec 29, 2006 3:56 pm
my cd player is a audio planet
PostPosted: Fri Jul 20, 2007 7:01 am
no the bigger one on any head unit would be the constant positive wire, not the acc + wire, all aftermarket head units work similar to a amp, 1 wire has power on it all the time, 1 wire switches with the ignition and 1 wire is ground.
you just have to disconnect the constant 12v wire (yellow) while the stereo is running to find that out, the stereo should shut down, even if the key is still on, cos all running power is supplied to the head unit thru the constant 12v, as well as memory when it is off, the acc wire just switches the stereo with the key.
