It is currently Sun Feb 18, 2018 2:14 pm
PostPosted: Sun Jul 08, 2007 6:15 pm
has anyone used the parcel shelf to mount an amp and sub or any other sort of combinations of speakers?
I was going to build a fiberglass foam core cuz i figured it would be stronger than the stock parcel shelf.
any ideas? pics? or words of wisdom from anyone whos tried this?
James
<a href="http://www.BannerBreak.com/"><img src="http://10.UploadMirror.com/uploaded/7/549/banner_break_02_08_2007_17_01_41_54321.gif" width="468" height="60" border="0" alt=""></a><br><a>
94 swift GT
87 turbo sprint project car
95 tracker
94 metro xfi
<a href="http://www.last.fm/user/jamesissweet/?chartstyle=basicrt10"><img src="http://imagegen.last.fm/basicrt10/recenttracks/jamesissweet.gif" border="0"></a>
PostPosted: Sun Jul 08, 2007 6:20 pm
lost of people have mounted 6x9s and other speakers to it, i think i sun would be a bit to much weight for it. you could probably wount your amp up there for easy access to it, dont know how it would like sitting in the sun there though.
PostPosted: Sun Jul 08, 2007 7:00 pm
King of Pompous
Even 6.5"-6x9's will cause it to sag if it isn't reinforced. After you've reinforced the shelf...you need to reinforce the plastic panels holding it up :P.
LNLC Founding Member
PostPosted: Sun Jul 08, 2007 11:53 pm
that was the plan, i think a foam core fiberglass shelf would be pretty strong with minimal reinforcement, maybe a few ribs or something.
but the hard part would definitely be making sure the plastic that holds the shelf is strong enuff....
anybody got any pics for some brainstorming?
94 swift GT
95 tracker
94 metro xfi
PostPosted: Mon Jul 09, 2007 11:19 am
King of Pompous
You can use the factory shelf and fiberglass from underneath to reinforce it some. Use a couple of pieces of 1/4" rope on the underside and cover them with the fiberglass. That will make them into reinforcement ribs and they don't weigh much at all. You could also use dowel but obviously it won't bend around corners like the rope will.
PostPosted: Mon Jul 09, 2007 1:33 pm
i would much rather fab up a parcel shelf using the factory one i have as a guide, i think a fiberglass one painted to match the car would be pretty sweet.
and if im building one from scratch i dont see why making up some sort of reinforcement o the bottom out of more foam wouldnt be a problem.
we buy alot of foam for fixing holes in boats etc so i know that it would be more than strong enuff and i know how to work with it.
94 swift GT
95 tracker
94 metro xfi
PostPosted: Mon Jul 09, 2007 1:41 pm
King of Pompous
Ahhh IC what your saying now. I thought you wanted to reinforce the factory piece with foam and glass. By all means if your starting from scratch use the foam to make your reinforcements. I have bought sheets of styrofoam insulation and cut them to the shape I wanted using a rasp and knife and then covered it with glass. It was brutaly strong and weighed nothing.
PostPosted: Tue Jul 10, 2007 3:06 pm
styrofoam insulation eh? i guess the marine grade foam they use to make boats would be a bit of overkill then i guess lol.
94 swift GT
95 tracker
94 metro xfi
PostPosted: Tue Jul 10, 2007 3:51 pm
King of Pompous
Depends what your doing I guess. In my case it wasn't being made to hold up a lot of weight. In your case I would want something a little more rigid as a core or a thicker glass layer.
PostPosted: Tue Jul 10, 2007 8:48 pm
well im thinking at least a 10 inch sub and possibly an amp or possibly mount the amp on the floor in the back above the spare tire OR on the back of the seat.
94 swift GT
95 tracker
94 metro xfi
PostPosted: Tue Jul 10, 2007 10:01 pm
King of Pompous
I think you need a lot of engineering to build up the shelf to hold a sub (assuming its in an enclosure) and amp. I suppose you could set it up free air to lose the weight of the enclosure but you need to seal up the area under the parcel shelf or you'll have cancellation.
PostPosted: Thu Aug 09, 2007 7:21 am
i just made mine out of 10mm ply with 2 pine ribs, holds 2 6x9's perfectly, just spray painted black for now, will cover with carpet later.
