It is currently Thu Jan 18, 2018 1:13 am
PostPosted: Sun Aug 12, 2007 10:06 am
its usually blue, i think i mite have the wright one to work my fli sub but it won't work. there is no light from the amp or the sub. is it because i don't have a good earth?????????
SWIFT GTi, own one and you'll understand :)
PostPosted: Sun Aug 12, 2007 2:58 pm
usually it is the blue one, I'd recheck your amp ground/earth and your power wire to your amp
93 Geo Metro - 3Tech 10 Degree Pulley, UDP, Foam Intake, Two Brothers Racing Muffler
PostPosted: Sun Aug 12, 2007 4:38 pm
Recheck your manual voor the correct cable, and indeed mostly it's the blue wone :)
If you're not shure if the ground cable is connected properly correctly your can connect a wire from the + of the amp to the remote connection on the amp.
Before you do that you need to disconnct the remote wire that's connected with the headunit otherwise you give your HU 12v ;)
On this way your amp would be switched on without your headunit is connected.
PostPosted: Sun Aug 12, 2007 5:45 pm
Depending on the deck blue is also power antenna. Tune a radio station in and see if that turns your amp on.
PostPosted: Mon Aug 13, 2007 4:45 pm
But would a unplugged remote wire cause no power to the amp. If i unplug my remote wire there is still power in my amps.
PostPosted: Mon Aug 13, 2007 5:06 pm
What can I say...you wired them ;).
Where did you get the remote wire from on your amp?
PostPosted: Wed Aug 15, 2007 4:29 pm
cheers men for the help, what you mean, i got it from the remote connection. i hope it's not my amp because the subs work, i checked them off 6x9 cables. :?
PostPosted: Wed Aug 15, 2007 9:01 pm
Sorry...I had replied to JSwift and his amp problem. You could run a 12+ from the battery right to the amop and see if it turns on. If it does you know the problem is somewhere in the remote wire.
PostPosted: Thu Aug 16, 2007 4:38 pm
i'll chance that :D
PostPosted: Mon Aug 27, 2007 7:11 am
'zuki addict
But don't leave it permanently like that, as your amp will stay on 100% of the time, and drain your battery.
http://www.cardomain.com/ride/799959
http://www.bdmotorsports.net
PostPosted: Mon Aug 27, 2007 3:03 pm
yes that is true thanks
