It is currently Fri Feb 23, 2018 9:56 am
PostPosted: Sat Dec 29, 2007 11:36 am
I put my system back together a few months ago, and I was wondering if one aspect is properly hooked up.
So it all starts with the power wire going to the positve terminal on the cap. Then the ground wire from negative terminal on the cap to the chassis (near the spare tire). Then the power wire being forwarded from the positive terminal on the cap to the amp. However I did not ground out the amp. Is this ok? System seems to work good other then the fact that when I turn the bass up it cuts out when I'm idling.
1994 Geo Metro 5 spd: All stockish. Re-built head, and lots and lots of donar parts :) B to the ER'
1995 Camaro Z28 6 spd: Magnaflow 3" Cat-back, K&N, skip shift elim. and thats it...for now.
PostPosted: Sun Dec 30, 2007 12:11 am
The amp needs to be grounded from the same negative post on the cap.
PostPosted: Sun Dec 30, 2007 1:13 pm
so you mean from the amps negative terminal to the caps negative?
PostPosted: Sun Dec 30, 2007 7:08 pm
The cap sits inline between the battery and amp. Pos from battery to cap then from cap to amp. Same with ground. The ground can come from the body to the cap and then to the amp.
PostPosted: Mon Dec 31, 2007 3:36 am
Ah ok gotcha man, maybe my bass won't cut out quite as much once i do this now. Thanx man!
