It is currently Sun Feb 18, 2018 3:58 am
PostPosted: Mon Apr 21, 2008 10:19 am
ok so ive got a rather basic install at the moment, pics below, none of the components are amazing but they work so im happy haha. basically what im look at doing is creating a whole new boot install (pic below again), two amps behind boxes with frosted perspex windows, two ported boxes and then a custom shelf.
Before i go ahead and do the install i want to make doubley sure i am going to be able to power it, as you can see im using 4gauge cabling for the power and earth, both distributed down to 8gauge. I will be upgrading the big 3 but i want to know if my alternator will be able to power the lot, and if not, where i can get a bigger alternator.
the spec of the system will be...
1200w amp powering 2 x 10" sony xplod subs (1100w each)
600w amp powering 2 x kenwood 400w 6"x9"s
not a huge amount, but i dont want alt problems further down the line.
cheers for all the help,hope you like the plan!
pics:
PostPosted: Mon Apr 21, 2008 1:04 pm
That is a lot of power you will be pulling from the stock battery causing more work from the stock small alt. I hope you are not running a stock battery. I would upgrade to a larger alt and a larger battery so you wont have any interference with any of your other elec....lighting
RG
1993 Suzuki Swift 1.3L GA
http://www.pctek4you.webs.com
PostPosted: Mon Apr 21, 2008 1:25 pm
thats the sorta thing i wanted to know, so a larger battery and alt, any ideas where i can pull a larger alt from?
PostPosted: Mon Apr 21, 2008 2:02 pm
I am not posotive, but I am sure I read somewhere you can use a 105amp alt from a 89 camaro. Let me check around for you
PostPosted: Tue Apr 22, 2008 4:59 pm
Oh, just read your post. Sound like a good small system. You could us a optima battery and I have seen Suzuki that are made for sound compition using Ford alt.
Love the way the West coast feels.
