It is currently Tue Feb 20, 2018 11:26 pm
PostPosted: Thu Sep 04, 2008 9:38 am
i got two sony 51/4" 4 way speakers on my front doors and two 5 1/4" speakers on my back doors. two 6x9s in the rear with a 12" kicker and a 12" german compation sub in a ported box running off a sony 1200 watt amp with a 1500 watt compasitor. i have the other kicker but planning to get a three sub box and run the kickers off the sony and and get another 1200 watt amp to push that german sub. so yah its going to rock my geo.
PostPosted: Sun Sep 07, 2008 10:35 am
Rock you geo? Be lucky it doesn't start to fall in pieces when the bass starts hittin.
Love the way the West coast feels.
PostPosted: Sun Sep 07, 2008 8:13 pm
Got any picture of your setup bro? People will definitely be hearing blasting bass from a mile away. :)
"You brake and then turn the wheel, step on the clutch, and pull the e-brake. Release the e-brake, go into countersteer mode, then wait. Wait until you know the car is facing the corner exit direction. then you smile and slam on the gas as you exit the corner." - Keiichi Tsuchiya.
What is power without control?
PostPosted: Sun Sep 07, 2008 9:21 pm
if you're running the stock alternator off of your metro you will be only getting about 500 watts into your amp anyways, because of the 55A generator.
PostPosted: Sun Sep 07, 2008 10:18 pm
would you know of any other alternator that i could use.
PostPosted: Mon Sep 08, 2008 12:37 am
You won't need one to run those Sony amps...or your compacitor.
PostPosted: Mon Sep 08, 2008 8:41 am
i kinda figured because i was just going to get another compasitor for the other amp and a optima battery so that should keep my alternator from going out.
PostPosted: Mon Sep 08, 2008 11:21 am
Yeah, that will work. Guess you really lick big bass to have thought it all out already.
PostPosted: Mon Sep 08, 2008 9:28 pm
you're actually going to run two compasitors? :shock:
PostPosted: Wed Sep 10, 2008 11:34 pm
i heard that the best thing to do when upgrading the alternator is to get it re-wound at a shop and this is usually cheaper than buying a bigger one and making a custom bracket/etc for the new one to fit.
PostPosted: Thu Sep 11, 2008 12:42 am
The physical size of our alternators makes it very dificult to get rewound to higher output. You also need to remember that when you wind something for more output you lose a good deal of output at idle.
PostPosted: Wed Oct 08, 2008 12:36 am
http://cgi.ebay.com/ebaymotors/_Car-Tru ... 06.c0.m245
Bong,Bong,Bong....zuki's
