It is currently Wed Jan 24, 2018 5:11 am
 Post subject: Larger Antenna
PostPosted: Sun Oct 26, 2008 10:45 pm
I have a 91 geo metro and the antenna on the roof is only like 3 inches long. Needless to say its a worthless POS and I don't get very good reception. Any ideas where I can get something cheap and better to replace it with.
 Post subject: Re: Larger Antenna
PostPosted: Mon Oct 27, 2008 12:39 am
not an expert but what happens if you just soldered the antenna wire to the body ? wouldnt that just give a big large antenna then ?
PostPosted: Mon Oct 27, 2008 7:06 am
I used an antenna from a yard sale and mounted mine internally................
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Mon Oct 27, 2008 12:53 pm
Assuming that the antenna is not broken off, you will have three telescoping sections that can be pushed flat to the roof line. Yours probably is bent and is binding. Worst case scenario, replace with one from E-Bay. I saw a new one for $20 plus shipping there.
PostPosted: Tue Oct 28, 2008 1:50 am
i've personally never had a problem with the antenna
used to have a old sony tape deck with cd/changer, got amazing reception
now i got a clareon mp3 deck and get pretty good reception, not amazing but can't complain
(actually now i dont get any, the antenna is unplugged for some reason)
08 Civic Wife's car
PostPosted: Wed Oct 29, 2008 5:55 pm
Mine appears to only be one section about 4" long I can't push or pull it out.
ANyways I traced the issue to my HID headlights causing interfearance with my reception. I think a longer antenna would pickup more signal and help cancel out the interfearance from the headlights. I'm not really sure what else can be done but listening to the stereo at night is impossible right now.
PostPosted: Wed Oct 29, 2008 6:45 pm
solution: buy an xm reciever
the lolcar family
PostPosted: Thu Oct 30, 2008 12:37 am
I don't want XM, and I beleive ti will also be affected by the HID lights.
PostPosted: Fri Jan 16, 2009 7:20 pm
Since my car is busted and ready to be junked I tried pulling on the antenna really hard...and it finaly broke loose and came out! of course my radio does not work now since the car is dead and will not start :P
