It is currently Wed Jan 24, 2018 6:48 am
PostPosted: Sun Jun 27, 2010 3:57 pm
alright, found a pioneer d8400m class-D its 1200 watt amp(50$)!!
i will be running this amp to one sub,(all i think i'll need in my hatch)
i will be replacing all my stock speakers eventually and i will use another amp to run those.
i wanted to get an Alpine Type-R
but i want a sub that is good for rap and techno
and i have seen people say type-R are more for rock
any input is appreciated
PostPosted: Sun Jun 27, 2010 5:37 pm
i really like old kove armageddon subwoofers. they were based in california so there should be used ones all over out there. the company sold out to us amps a couple of years ago but they made killer subs. a single 12" with dual 4 ohm voice coils (for a 2 ohm load) should make that class d 1200 watt amp sweat bullets without melting the sub. :twisted:
i used 2 10" armageddon subs, each driven by a separate 1200 watt hart professional amp for a while and it was stupid loud. =)
PostPosted: Sun Jun 27, 2010 6:42 pm
Just so you know the real power on that amp is:
300w @ 4ohms
600w @ 2ohms
Just an FYI.
My cars:
PostPosted: Mon Jun 28, 2010 8:30 am
The type r will be fine for techno and rap. Just follow the guidlines Alpine gives for a ported enclosure and you should be fine.
PostPosted: Mon Jun 28, 2010 2:00 pm
I have a type-r 12". The thing is in a ported box. I like the way it sounds with all different types of music. I listen to pretty much everything from country to rap to rock just as a couple examples.
1994 Suzuki Swift GT - Genie Header w/ 2.25" exhaust & fart can, Lowered 1.5" on intrax springs, 25% u.d pully
http://www.cardomain.com/ride/3168439
PostPosted: Fri Jul 09, 2010 5:04 am
I have two type R 12's in my Ford Probe and they POUND HARD!! My buddy also has one type X 12 and it is pretty much just as loud!
1987 Turbo Sprint
PostPosted: Wed Jul 28, 2010 1:42 am
I have a 10" Type R in my LS400. I have it running off of a 500watt RMS Alpine amp. I have it turned waaaaay down, but it still hits sharp and clear. I'm very glad i went with it over a 12, however i have a ported box. I wish i would have gotten a sealed box, but i couldn't pass on the price of the ported box. I would be willing to bet that in a hatch it would hit much much harder.
Kyle
PostPosted: Wed Jul 28, 2010 4:50 pm
the Type R in a vented (ported) enclosure... any prefrance of size?
Also a Kicker CVR
if you get a dual 4 ohm and wire it in series then turn the amp down a smidge it should power it well. run it in a 1.8 cui vented enclosure it should rumble verry well.
installed one in a friends pickup with an amp simalar to yours. hes putting out 135.6 db 1 foot from the windsheild, drivers seat, passenger door open.
hope ale goes well
My Girls
Sophia
1.0 High Output. 3tech goodies, tonz of audio and a CB
Taylor
My second project 1.3L big block GTi twin cam
Team swift project threads underway for both cars until then check out my profile @ GMF links to my cars are in my sig
http://geometroforum.com/profile/545845/
PostPosted: Mon Sep 27, 2010 9:59 am
Diamond audio D6 subs. End of discussion! :lol:
~the other Ralph~
Certified Suzuki Owner:
PostPosted: Tue Sep 28, 2010 1:47 am
Paul Jr.
No sub is better for any type of music than another, it's just tone and volume, depending on size and material of the cone, magnet size and strength, sealed or ported box and how big the box and port is or isn't. And last but not least, the power and type of amp used.
My setup is an Alpine MRP-500 Monoblock Amplifier running to a 10 inch Alpine Type R in a 14"x14"x10" sealed box (500W@2ohms). The result is smooth, round, yet firm bass with punch you can be happy with but more emphasis on the actual tone of the bass. I was rather happy I didn't get a 12 because the smaller speaker allows for a bit more punch than its big brother while covering a little more of the higher bass frequencies, which to me as a bass guitar player, are important.
What you should do, is read lots of reviews, keep an eye out for product stompers, and go to your local retailer and listen to it first hand compared to others.
IMHO:
Best punch: JL audio and MTX
Best tone: Rockford Fosgate and Alpine
(lower frequency ranges and smoother sound = larger diameter sub with more air space around it)
(higher ranges and more punch = smaller diameter with less air space for the sound to play with)
Hope this helps,
Cheers,
~Jr
Edit: by the way, I listen to a lot of rap/hip hop, and rock, but more recently getting into techno and house stuff.
1993 GT (240k) - K&N Air Filter, ProCar Bucket Seat, Walker Exhaust, Mk2 bumpers, EDM lights
" 6' 6", ain't nobody sittin' behind me unless they're an amputee "
PostPosted: Tue Sep 28, 2010 8:24 am
You need to be very careful with that statement. A lot of the "punch" and "smooth sound" you get is not so much from the sub as it is from the enclosure. Yes, some subwoofers will exhibit better tonality than others but this is from its design parameters and not the size. I can take the same subwoofer and put it in 3 different enclosures and it will go from a low end frequency monster to a punchy rockstar to a well rounded "jack of all trades" system. Live concerts use large format drivers (15", 18" and 21") in the speaker arrays. They even use 10", 12" and 15" drivers for midbass duties. The size of the driver isn't dictating the sound (tonaly speaking) here. Its all in the design of the speaker and the enclosure its sitting in. You should have heard the "punch" I was getting from my 15's in the Audi with its infinite baffle setup...its was like getting hit in the chest with a 2x4 ;)
PostPosted: Tue Sep 28, 2010 9:26 am
Paul Jr.
That definitely makes sense, I'm just speaking from what I've looked at, and the things I've played with. Never actually taken a sub and put it in different box setups, I should actually try that
