It is currently Sun Jan 21, 2018 4:35 am
PostPosted: Fri Aug 02, 2013 4:45 pm
Hi, I have a 2011 Swift ZC72 with OEM deck. Push button start etc. There's an USB button on the deck but when I press it nothing happens, also there is no USB port next to the cigarette lighter like on other models.
Is this normal or is something wrong. I'm assuming it's not the original set for the car,but even so the USB should still at least switch the set to USB mode.
PostPosted: Sat Aug 24, 2013 4:48 pm
Most likely since you have not located the usb port and connected a device to it,
the unit wont switch to usb mode until it has an external device to recognize.
My Mini does a similar thing where it wont allow me to select an external Ipod
unless its plugged into the stereo jack.
