It is currently Mon Feb 19, 2018 8:20 pm
Post new topic Reply to topic  [ 172 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Tue Sep 19, 2006 4:51 pm
so vela, there is something i dont understand here. If i were to buy this setup from you. You send the kit or whatever to me, i just unplug the old stock chip and install your board or what? I have a completely stock ECU, do i first have to remove the old chip and solder in one of those sockets or what? Also, congrats and i am very impressed on you accomplishment. Brilliant, just brilliant.
when the clutch drops, the BS stops
"Life's a rally, cut corners"
PostPosted: Wed Sep 20, 2006 2:57 am
Mad Scientist
Yes Greg, you just have to unsolder the stock chip that's in your ECU and solder in the socket that you get from me, and plug in the board that I've allready made and tested for you. The location of the LEDs and the push button is your choice. Thanks for that coment!
 Post subject: chip
PostPosted: Wed Sep 27, 2006 1:45 pm
got my chip and all parts are made well. i havent had a chane to test it as i am haveing my adepter fitted at my local tv repair shop. will post as soon as i have tested it. 8)
edit
Had to desoler the eprom myself after going to lots of tv repair shops etc and being told that they cant do it.
i used copper braid anda good solder iorn however it was hard work people here are some pics 8) .by the way i the chip works great meaning i would recomend people get one.
PostPosted: Fri Oct 06, 2006 7:01 am
Mad Scientist
Hey, thanks! I didn't get the mail about this post becouse you edited it. Cheers!
Come on people, I still have a few boards laying around. It's stupid to waste money on fuel - give it to me instead! :lol:
PostPosted: Fri Oct 13, 2006 9:46 am
Mad Scientist
I PM'd few of the guys who were posting here about this... I only have a few kits left and i won't make more of them, (too much work and no time) so if you're thinking about it - let me know soon!
Cheers, Vela.
PostPosted: Sat Oct 14, 2006 2:28 am
spt-3x1.0 wrote:
would these be able to do any good in a G10 ECU?
you are SOOO about to get a title under your name. :razz:
PostPosted: Sat Oct 14, 2006 3:02 am
Mad Scientist
:lol:
No man, the switch is designed to fit the DOHC ECU and the programs in the chip are made for the G13B engine. The switch can be used in your car if it fits in your ECU with no clerance problems and if you have a performance chip for your car.
PostPosted: Sun Oct 15, 2006 6:59 am
I'm pretty sure the chip switcher will work with a G10 ECU, but I don't know chips you plan on switching though... (stock + stock?)
PostPosted: Tue Oct 17, 2006 11:29 am
Mad Scientist
IT assholes at work blocked teamswift yesterday! :ez_mad: I can't reach the forum from work any more. So if anyone needs me, please e-mail me at veltruski@yahoo.com
Cheers!
PostPosted: Wed Oct 18, 2006 11:28 am
You need a proxy server:
http://www.proxy.org
PostPosted: Wed Oct 18, 2006 4:11 pm
Mad Scientist
Thanks Lihtan, but I don't want to do anything yet. (don't want to get fired) They'll know what I'm up to, if I try it, for shure. I ordered broadband for home yesterday (don't ask me why I didn't do it sooner :screwball: ) So I should be covered soon. Thanks.
PostPosted: Wed Nov 08, 2006 9:41 am
I got one as well!! Man I'm so happy right now! I couldn't get the switch earlier becouse of the lack of money. But now i have it installed in my car and I'm just so thrilled!
Great work Vela! We're waiting on your new projects! 8)
:thumbsup:
Ivan
PostPosted: Sun Nov 12, 2006 11:22 am
Who's this? 8)
http://www.youtube.com/watch?v=NM3vOVDLZ7E
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Mon Nov 13, 2006 2:20 pm
Mad Scientist
I think it's Gabber, this is filmed in Zagreb so I think it's him.
PostPosted: Wed Nov 15, 2006 2:31 pm
Question I have is about whether or not the fuel maps on the 1.0 and 1.3L motors on the '89-94's, and on the OBD-2 95-01's had a good lean down-the-highway mode. I'm told that the early EEC-4 Fords had such a program, as Ford had some EPA credits that allowed them to get away with increased NOX emissions. When running right, my beater truck , '86, with the 2.9 gets 28MPG at 70 miles per, which aint bad for a 3300 lb brick. From what I recall reading, 3-way catalysts require a rich/lean cycle of fuel delivery to work correctly, and this ultimately costs fuel economy, particularly on highway running. Some of us are more concerned with burning less fuel than polluting rural areas' air. For those of us who are willing to pollute a bit more, a chip that would run leaner in 5th gear at steady throttle openings might give us more MPG's is of interest.
Do I have my facts right? Some of y'all engineers are more up on this than I am these days.
PostPosted: Mon Nov 20, 2006 5:01 pm
Mad Scientist
So you want more MPG with a stock chip modified to run lean at lower rpm? That would cost some money and alot of time (witch I don't have) to make and noone would buy it. That's why this switch was made in the first place, read the first post of this thread.
 Post subject: i just got it
PostPosted: Wed Dec 13, 2006 8:23 am
i just got in the mail today, i am going to install it and let you guys know how it goes!
 Post subject: it's done!!
PostPosted: Thu Dec 14, 2006 8:11 pm
OK GUYS, I DID IT YESTARDAY, AND YES I MUST USE CAPSLOCK BECAUSE THIS SUPER DUPER THING ROCKS!!!!!!!! :) :) :) :)
This is by far the best investment I ever made into the car, the chips works flawlessly AND the timing and fuel maps are WAY BETTER THAN MY PREVIOUS CHIP!!! No problems on low end torque, its mapped brilliantly from the start of the rpm all the way to redline. The car pulls like a mofo!!!
Another advantage is that I can simply press the switch when I use nitrous to go back to the stock mapping so that the timings are not as agressive. Very practical.
Anyway, I highly recommend this chip to everyone, it's a cheap and very effective mod, the switch is smooth and I did it while driving several times. Simply awesome :!: :!: :!: :!:
PostPosted: Sun Dec 24, 2006 10:19 pm
Ok I did mine also. It's been installed now for a lil over a week.
The results?
It pulls VERY VERY HARD/STRONG to 8000rpm!!! Even in 4th! That was a shock to me! :shock: It was clearly an upgrade from my first chip. I mean, the chip I had was awesome! but this one surprised me in 4th gear. Less road is needed to reach the same high speed being reached with the first chip.
Switching is a dream! It's so fast it's incredible. You will notice rpm @ idle will go up a little, and when you lift off the gas pedal, the engine speed won't fall as fast as stock program.
It's highly recommended.
Thanks Vela. Good Job!
2003-EVO7 GT-A
PostPosted: Mon Dec 25, 2006 2:14 am
eegads! This is incredibly interesting stuff Vela! :shock:
Would this kind of thing work for a MK1 like mine?
Before downloading, you may want to read this: http://www.teamswift.net/viewtopic.php?p=246047
Mark 1 Workshop manual: http://d01.megashares.com/dl/qAE1O4k/SA ... Manual.PDF
mk2/mk3 GTI manual: http://d01.megashares.com/dl/7pbE6NH/Su ... K2and3.zip
Rock stock 1988 AA33S SA413 HEJ574 Holden Barina GTI rebuild complete! http://www.teamswift.net/viewtopic.php?f=31&t=39669 - Deceased and stripped for parts
1987 AA33S SA413 HEJ574 Holden Barina GTI MK1 - gone
PostPosted: Mon Dec 25, 2006 5:12 am
Mad Scientist
Yes, I think it should... if the ECU is the same, and I think it is.
PostPosted: Tue Dec 26, 2006 12:03 pm
Here is how I mounted mine:
http://www.teamswift.net/album_page.php?pic_id=10492
The view @ my cluster:
http://www.teamswift.net/album_page.php?pic_id=10493
edit:
Some shot I took at night:
http://www.teamswift.net/album_page.php?pic_id=10513
http://www.teamswift.net/album_page.php?pic_id=10514
2003-EVO7 GT-A
PostPosted: Thu Jan 18, 2007 2:13 pm
I recieved the chip switch. Nicely made. Can't wait to try it!
happiness is doing your best when the going is easy.
PostPosted: Wed Feb 07, 2007 10:22 pm
Track results:
On 26th Jan I went to the track and managed to do 2 runs only with the Chip switch:
Both runs were 16:38xx. 60ft were 2.6xxx and 2.7xxx.
My only mods include a Genie headers, single underdrive pulley and 8mm ignition wires.
I think it's time to invest in some good tyres. I believe I can do a 16:1xxx with the chip and some good tyres.
1/4mile speeds were 85.66 and 86.36.
This is just an update on the chip switch.
2003-EVO7 GT-A
