It is currently Mon Feb 19, 2018 1:42 am
 Post subject: difference
PostPosted: Sun Mar 30, 2003 7:01 pm
what's the difference between the swift gti and the cultus gti??? i know one is 100 and the other is 115 hp from the same engine. so how come that difference???? <p></p><i></i>
 Post subject: Re: difference
PostPosted: Sun Mar 30, 2003 7:22 pm
Here's the ones I know: Different intake manifold (flows better), higher compression, different cams. Might have different ECU and exhaust manifold. There should be some old posts covering it. <p></p><i></i>
 Post subject: yep
PostPosted: Mon Mar 31, 2003 2:17 am
That's all correct...except, some Cultus' had a 4WD chassis....they were homologation models. EXTREMELY RARE. <p></p><i></i>
 Post subject: Re: yep
PostPosted: Mon Mar 31, 2003 2:37 pm
mmmmm........acoording what you said, do you think that it will be a good idea if i ll install the intake manifold and the cams from the cultus, so i ll get around 10hp?????????<br><br>does anyone did that before?<br><br>tell me what do you think. <p></p><i></i>
PostPosted: Mon Mar 31, 2003 2:59 pm
If you can get the intake and cams go for it. The intakes are hard to find. Many people make regrinds of the cultus cams. As far as 10 hp don't know. I was told with a cultus intake,60mm tb, and bored MAF you could get 10-15 hp so with the cams and intake you could probably get 10 hp. <p></p><i></i>
