It is currently Sun Jan 21, 2018 8:17 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2  Next
PostPosted: Sat Jan 29, 2011 1:22 am
Hello everyone, I'm new here. I recently purchased a 1990 Suzuki Swift 1.6 GLX 4WD and as far as I know, it's one of few or maybe the only one of it's kind in my country. I'm from Lithuania if that says anything to the world. Originally purchased in the UK back in 2000 and brought back here. This car's seen some rough times and is in pretty bad shape, rust all over the body, so a lot of metal work and welding. It's done about 500,000km and not long ago the engine started knocking. I checked the compression and was surprised to see 16bar(232psi) in all cylinders. Just so you know, it's been running on low octane fuel for about 10 years, so that could be the cause, but I'm making no assumption. Could this be the cause or could there be something else and if so, what are the possible causes? Is it worth rebuilding this engine, or should I just swap one from a Vitara or Baleno instead? I also haven't been able to find a service manual anywhere, so if anyone has any info it would be much appreciated. This will be a rebuild of the entire car, from engine to interior, so if there's anything unusual I might encounter, please post it.
99 Honda CB600F Hornet
PostPosted: Sat Jul 09, 2011 8:24 pm
Check out my posts about these cars
http://retrorides.proboards.com/index.c ... read=90740
Make sure to make a post and get some pictures up please.
Just out of curiousity, what is the model number of your carb>
PostPosted: Thu Jul 14, 2011 11:30 am
I couldn't find my carb number, but it's stock.
I'm well into rebuilding this car now. I've decided to keep this engine, as it wasn't in bad shape, just needed the piston rings changed and the crank was sent to the machine shop, so it's almost done. The body is stripped and there's so much rust everywhere, but I wanted to save it, since it's an original JDM import. I've learned how to weld and started on the body work. So far I've cut out and welded up several big patches on the front and the wheel arches. The biggest problem though is the bottom. Huge holes everywhere and there are barely any spots without rust, luckily it's not all the way through, so it's just a matter of time and my time is free :mrgreen: Apart from that, everything is in good condition, the only part that needs replacing are the shocks and springs. Didn't find much after a search through ebay, so if anyone knows of any compatible bits from other cars, please let me know. I will post up some pics of the progress so far as soon as I get my camera connected :wink:
PostPosted: Thu Jul 14, 2011 1:51 pm
Its been a while since i looked, but perhaps the old subaru justy / swift cultus 4wd items are compatible.
I have a feeling that the front suspension is the same as the swift gti?
I think you should bring it back to the uk and sell it me :)
PostPosted: Thu Jul 14, 2011 2:53 pm
Nah, I'm keeping this one :-P
As far as I know the front brake assembly is different, not sure about other components, but I only need the shocks.
PostPosted: Tue Sep 06, 2011 12:56 am
Well I promised some pictures so here you go.
First off, this is how the car looked while it was still running.
Neglect, nothing more to say.
Now this, is how it looks at the moment, because I've been lazy.
Though I have had some work done by now, I taught myself how to weld and done quite a bit of body work.
You can see the extent of damage done, but that's not the worst part. The biggest problem is probably the bottom, as you can see the carpet of rust, and I do mean RUST, all over the floor and a nice big hole where the drive shaft center mount used to be.
A rusty boot and a rotted out fender. 3 of them in fact, 1 rear and both front.
In this next photo you can see the amount of metal that needs to be cut out in order to remove rust.
Most would probably call me crazy for doing this, but there are a couple of reasons for this.
1. It's an original JDM import.
2. This is probably the only car of it's kind in my country and probably there's not one other in a 1000 mile radius, so not gonna find another body like this.
3. And because I enjoy a challenge :-P
Oh and don't mind the weld seams, I haven't attended to them yet, just patching it up :roll: Had to get the engine rebuilt as well as it has done about 300,000 miles, but that's already taken care of. But the car did have a set of Monroe shocks that I'll be using to make a set of "Phonis" later, again because I like the challenge :-P
PostPosted: Tue Sep 06, 2011 12:07 pm
Wow very good job.
I have NEVER seen one as rusty as that, but i am glad you are sorting it out :) 8)
I guess the 300,000 miles does explain it
Do you have any spares? Carb etc ?
Here was mine, I ran out of money and the bottom end of the engine went, so the car was taken away for parts :( :
And here is my friends, he drives it every day :)
PostPosted: Tue Sep 06, 2011 12:17 pm
Love the spoiler, I wanted to get an evo 8-9 spoiler, but since they're carbon I can't afford one, maybe I'll fab one up :-P No spares, but all the mechanics are in good working order, the transmission is in a surprisingly good condition for such mileage :wink:
EDIT: btw is that an evo 6 spoiler?
PostPosted: Tue Sep 06, 2011 4:18 pm
You sure got yourself a challenge there... good luck!
PostPosted: Tue Sep 06, 2011 9:02 pm
YOU must REALLY like a challenge.
a rust free shell of the 2wd version would have really
helped on patch panels.... but ya got to work with what you've got.
keep us posted!
PostPosted: Tue Sep 06, 2011 9:50 pm
keep us posted!
I guess it would have, but the cheapest shell I could find was half what I paid for the whole car. I just got a big hood from the junkyard and chopped it up for sheet metal, works really well, plus I'm getting experience :-P
PostPosted: Fri Sep 09, 2011 1:47 am
Awesome project, i wish i could find AWD sedan's here in Holland.
PostPosted: Sat Sep 10, 2011 9:44 pm
Car is AWESOME man!!! I'd LOVE to have an AWD 4-door.
All Wheel Drive-187 FWHP @ 18 psi...... SHE LIVES!!!!
METRO SS Certified honda H8R
AHM NOT AN AHSOE!!! DO I LOOK LIKE AN AHSOE!?!?!?
PostPosted: Sat Oct 08, 2011 6:15 pm
Some progress.
Welding up front - done!
Started working inside. After a closer inspection on the rust in the passenger area, it turned out it's mostly surface rust, but there were a few holes that needed to be welded up.
image_id: 20988
Had to cut out a huge patch of metal in the lower corner of the passenger wheel arch and welded up a nice thick metal patch.
image_id: 20989
image_id: 20990
View from the inside.
image_id: 20991
The drivers side had significantly more surface rust, but far less holes. Just started on that.
image_id: 20992
Hopefully I'll be able to finish up welding until winter, so that I can paint it and finish it up. Otherwise I won't have any wheels for the winter :(
PostPosted: Sat Oct 08, 2011 10:56 pm
wow that is so much rust in there. makes me feel lucky that my problems are limited to the rockers and rear wheel arches.
PostPosted: Sat Oct 08, 2011 11:25 pm
It's not that bad, all you need is an angle grinder and time :-P
PostPosted: Sat Oct 08, 2011 11:33 pm
Kudos, props, and "attaboy's" a- plenty!!! :D
PostPosted: Wed Oct 12, 2011 8:37 pm
A legend in his own mind
$50 bux says Mike sat on that trailer hitch.
I'm just sayin'...
PostPosted: Wed Oct 12, 2011 9:38 pm
I'm just sayin'...
I have no idea what that means :? :lol:
PostPosted: Wed Dec 07, 2011 12:17 pm
A little update. Passenger side is finished, just have to relocate the rear control arm a bit, so there's some metal cut out under the back seats at the moment. The drivers side needed a new door sill, but I couldn't find one for a swift sedan, so I had a look around and bought an mk2 golf door sill and it was almost a perfect fit, just have to cut it a bit at the back. The rear wheel arch has rotted out, but I'll have one fabricated by a guy who's already done it a few times on this exact car :mrgreen:
image_id: 21157 image_id: 21158 image_id: 21159
So welding's almost done and then I'll prep it for paint and do some fiberglass parts over the winter. :wink: Hopefully it will be done by spring and I can finally drive it 8) Though I'm still desperate about finding that front lip :(
PostPosted: Thu Jan 05, 2012 12:56 am
Found a really clean sedan for sale locally. The guy wants $570 for it, maybe I can knock it down to 500 or even 400. But even at 570 it's a bargain, very clean, especially considering our roads and winters, probably imported from Germany not long ago.
image_id: 21197 image_id: 21198 image_id: 21199 image_id: 21200
Was wondering, I need rear arches replaced, both front fenders, all are $50 a piece, maybe even more, so I though I could buy this and use for fiberglass molds. And on top of that I'd have a daily drive, since I'm kind of jacking my girlfriends mom's ride atm :mrgreen: Then when I'm finished with my current project, I might do another 4wd sedan from this one, all parts necessary are available locally :D
PostPosted: Sun Jan 08, 2012 9:25 pm
at $550 that would be a STEAL... esp. if the inside is as nice as the outside
PostPosted: Thu Jan 12, 2012 4:06 pm
Was going through the adds just now and guess what I found.
image_id: 21207 image_id: 21208 image_id: 21209 image_id: 21210 image_id: 21211
Looks solid enough and it's posted for $50! :shock: No MOT, so there's probably something wrong with it and it's 300km away, but hell, for $50 I'll take it! I'd pay that much for a new fender and I only need it for a fiberglass mold. And I need a new windshield which costs a $100 :lol: Suspicious though, have to look into it...
PostPosted: Fri Jan 13, 2012 3:54 pm
that's the slow engine, but can be fixed later :razz:
PostPosted: Tue Oct 02, 2012 3:58 pm
Any update on this?
Guess what? I have just bought the 4WD one with the Evo spoiler from my friend 8) I'm not sure what Evo the spoiler is off, I will ask him.
It needs a lot of work so I am putting it in the garage.
