It is currently Thu Feb 22, 2018 11:53 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
PostPosted: Tue Dec 09, 2014 11:18 am
Allright, time for an update:
Here are a few things I've been busy with the turbo project. I'm doing this all by myself.
I've noticed the small little things takes a lot of time to get done.
Things still to do:
-Custom inlet / outlet holes onto intercooler (to make piping work easier)
-Intercooler bracket install
-Oil feed line and drain line install
-Wiring up of turbo timer, dual stage boost controller (se7en circuit)
-Socket install ECU
etc.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Tue Dec 09, 2014 4:54 pm
the project is looking good, man! :wink:
PostPosted: Wed Dec 10, 2014 8:05 am
Thank you. 8)
2003-EVO7 GT-A
PostPosted: Mon Dec 22, 2014 7:45 pm
I'm routing the vacuum hoses but I can't source small enough clamps. Can I just use tie reps on the vacuum hoses?
2003-EVO7 GT-A
PostPosted: Mon Dec 22, 2014 8:56 pm
i have used zip ties on some small lines. i have popped a few, too.
when zip ties don't hold i replace them with clamps.
on my blue monster turbo3 project i did everything in special aba clamps from 3mm up to 26mm.
PostPosted: Tue Dec 23, 2014 1:46 pm
Awesome. Thanks again!
2003-EVO7 GT-A
PostPosted: Sun Dec 28, 2014 5:24 pm
ok so here goes another update.
After turning the catridge and compressor housing I had to fab up a bracket for the actuator. It's being held by 2 bolts at the water in/out of the turbo. I'm not going to use the water cooling.
Also connected some hoses for the oil catch can. The oil catch can is going to be inside the car. Not much space in the engine bay. I'm still thinking if I should reroute the breather filter of the catch can to the outside. Don't want the gases in the cabin.
For the oil feed line I used 4An fitting hoses, 1" extension 1/8" bsp male/female, A T-fitting for the turbo feed and relocation of oil pressure switch sensor (15psi) for warning light and oil pressure sending unit for the gauge.
For the Oil return I used a "no welds" 45 degrees fitting (10An) and also an adapter with 5/8" barb for the drain hose. 5/8" is the diameter of the return of the TD04L-13T.
The test fitment of intercooler piping. Most intercooler piping inside diameter are 2".
I still have to close one side of intercooler and open up a 2" 90 degree so I can connect the compressor housing to it.
Everything is still test fitted. When I'm done and everything is in it's place I'll tighten them up securely and use the zip ties for the vacuum hoses.
2003-EVO7 GT-A
PostPosted: Wed Jan 07, 2015 12:21 pm
Got the car painted last weekend. 8)
Sorry for the picture quality of the last two pictures. it was getting dark.
There are still some bodywork left like painting rubber / plastic seals etc.
FYI paint code is 8m6 from my altezza.
2003-EVO7 GT-A
PostPosted: Wed Feb 11, 2015 7:40 pm
I'm going to vent the crankscase directly to an oil catch can. Installed a 6an fitting with 90 degree.
Also sprayed painted my rims with white epoxy paint in a can that is used to paint fridges. :lol:
They actually turned out good IMO.
Also mounted the Apexi SAFC. I have yet to wire it up.
2003-EVO7 GT-A
PostPosted: Sat Feb 28, 2015 11:17 am
Could you give me the specs on the JE pistons
Thanks
89 Suzuki Swift Turbo
03 Infiniti G35 sedan
PostPosted: Sat Mar 21, 2015 12:10 pm
Thanks
I'm not using JE pistons in my turbo engine. :huh:
The pistons in the turbo engine are stock.
2003-EVO7 GT-A
PostPosted: Fri Jun 10, 2016 8:13 am
Quick update:
Removed the fuel tank. Installed a 5 gal. fuel cell.
Also installed an Aeromitve fpr. The knock off was giving me issues. Buy the real thing the first time.
Also have a marshall pressure gauge insalled. And an external walbro fuel pump.
THere is a chance I might go to the track tomorrow again. 8)
2003-EVO7 GT-A
PostPosted: Fri Jun 10, 2016 8:33 am
A pic of the last time I was at the track.
2003-EVO7 GT-A
PostPosted: Sun Jun 12, 2016 8:42 pm
Did a few runs on the 1/4 mile yesterday. My best run is a 14.10 @ 106.4mph. I was boosting 18psi on a stock engine.
More info and pics here: viewtopic.php?f=24&t=61742
2003-EVO7 GT-A
