It is currently Sun Jan 21, 2018 9:50 pm
 Post subject: Swift gti RWD
PostPosted: Tue Nov 17, 2015 6:09 am
Hi all.my name is dan from London.i have a 1979 Vauxhall Chevette and I just bought a 95 gti engine.i want to change it to rwd and install it into my Chevette.i have got a Suzuki jimmy early gearbox that I'm going to make an adaptor plate to take a ford type 9 gearbox.id love a set of good race cams.and some info on a rwd manifold.thanks for any help. :D [album][/album]
 Post subject: Re: Swift gti RWD
PostPosted: Tue Nov 17, 2015 1:49 pm
Welcome to Teamswift, the suzuki engine is a bit small for a shove-it isn't it? I seem to recall the rally versions had 2.4l engines?
Have you checked out Runbags rwd swift?
PostPosted: Tue Nov 17, 2015 3:36 pm
No she is only going to be a wee road car.not a rally car but in looking for about 140/150 BHP.
No I haven't seen his car.could you forward me a link?and Anyone have a set of cams?and lighten flywheel or any other good ones? Thanks dan
PostPosted: Tue Nov 17, 2015 3:46 pm
With the heavier weight of the chevette, your main concern will be getting torque from it
___________________
89 Swift gti
PostPosted: Tue Nov 17, 2015 3:49 pm
I don't think there is much difference in weight compared to a swift.its only a hatch back.
PostPosted: Tue Nov 17, 2015 4:48 pm
Make love, not moderators
http://www.teamswift.net/viewtopic.php?f=6&t=9156
It's a long thread but worth reading.. Lots of pictures too.
PostPosted: Tue Nov 17, 2015 5:53 pm
Yea I seen it after that message!!a lot of work what he was doing!! Mental.but I don't want a turbo so most of his stuff is no good to me.the exhaust manifold is the big one.i got an early Suzuki Jimmy rwd sump and I can get cams of cat or piper or Kent.amy ideS on the best ones would be appreciated.
PostPosted: Tue Jan 12, 2016 1:52 am
Can you not just fit Jimmy box?
There has been many rally car with G13B engine is Toyota Starlet RWD and so on.
You have covered your oil sump so you will need to have an exhaust manifold. I think there was aftermarket one for fitting into Jimmny.
Kent or Piper will regrind yours for you but asking Suprf1y will be better for you.
If you need spare let me know as I have few bits.
Atchi
