It is currently Tue Jan 16, 2018 6:37 pm
PostPosted: Sat Jan 16, 2016 12:42 pm
I put larger wheels and tires on my metro convertible and now sometimes if there is too much weight in the trunk the rear tires will rub in a sharp corner or on a bad bump in the road. The rubbing is on a soft spot inside the fender so I'm not worried about cutting the tire but I don't want them rubbing on the body.
I've already put in spring spacers but the rear springs are weak and sagging. It's time to replace them. So what I need to know is, is there a taller and stiffer rear coil that will fit in the 91 Metro convertible automatic transmission? I'll just get a new alignment after I get new springs.
PostPosted: Sat Jan 16, 2016 1:16 pm
Use 95+ Swift/Metro 3 dr hatch springs . They will lift your ride by an inch or so and make it look like 4WD but it wont rub
PostPosted: Sun Jan 17, 2016 3:00 pm
Thank you very much! I'll start looking for the springs right away. Are they an exact fit?
PostPosted: Sun Jan 17, 2016 9:44 pm
Yes . Im using 89-94 springs in my 95+ 3 dr to lower it about 1 1/4" . 95+ springs will do exact opposite in 89-94
PostPosted: Tue Jan 19, 2016 10:35 am
I used front springs off a 99 kia sportage on the back of my swift to keep it up where it belongs. I cut about 2 coils off if i remember right. Now it sits about the same height as with h&r springs, but it doesn't bottom out with a load in the car(or while racing which was my problem).
