It is currently Thu Feb 22, 2018 2:24 pm
 Post subject: swift gti not running
PostPosted: Thu Jan 21, 2016 4:05 am
Hi all I have 1992 swift gti g13b it has randomly gone awal ,,, cranks over but wont start so we has tested distributor, coil, injectors, all working but there is no fuel pump or spark on ignition turn over ,, also fixed a maf wire can someone help please thanks in advance ,,,
PostPosted: Thu Jan 21, 2016 10:37 am
No fuel and / or spark could mean a fried ECU. A shorted maf wire could fry an ECU...
Make sure the maf wire is all the way good and than try another ECU (if possible).
If the ecu is fried it could be repaired. You should search the forum for this solution.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Thu Jan 21, 2016 6:07 pm
There is a fuse in the box under the hood that would kill both fuel and spark, i think its 15 amp for the computer. You might want to check it just in case. I Blew 2 of them in a row when my evap solenoids got shorted out.
Listen to thine engine and mind thine tach, lest thine whirlybits seek communion with the sun.
1989 Suzuki Swift GTi, A work in progress as always.
