It is currently Sat Feb 17, 2018 8:49 pm
 Post subject: TIRES?TIRES?TIRES ?
PostPosted: Fri Feb 12, 2016 8:18 pm
Where should I post asking about 185/60/14 tires?
I would like to know if anyone has decent luck with anything in particular?
I wore out a set of Yoke A032 R , but not made anymore .
Any suggestions ....I am not buying new rims...btw...
 Post subject: Re: TIRES?TIRES?TIRES ?
PostPosted: Fri Feb 12, 2016 8:44 pm
Yokohama makes some real good ones.
PostPosted: Sun Feb 14, 2016 12:18 pm
Yokohama shows NO 185/60/14 in their catalog, that I can find............except snow tires
PostPosted: Sun Feb 14, 2016 10:44 pm
I had general altimax hp tires and they were decent for the price
___________________
89 Swift gti
PostPosted: Sun Feb 14, 2016 10:48 pm
Well, what do you want to do?
If you need sticky street tires for autocross, then Dunlop Direzza ZII Star Specs are the ONLY "extreme performance summer tire" that you can get in that size.
Yokohama actually makes the S drive in 185/55 R14 which is a better size for our car--not quite as sticky as the above, but you get a small advantage in gearing and a tire with universally praised characteristics for breakaway and ride.
If you want a DOT legal track tire that you can get away with driving on the street, more or less, (don't try lots of highway miles...) then Toyo makes the R888 in 205/55 R14 too.
On the other end of the spectrum, I had some "Champiro GT Radial" all season no-name tires from China that were ok too. I won an autocross with them, but that doesn't mean you will, :lol:
PostPosted: Sun Feb 14, 2016 11:49 pm
Good point about the 185/55/14 S Drive....gotta keep options open ...Thanks for the tip !
