It is currently Tue Jan 16, 2018 4:32 pm
 Post subject: Coolant tube o-ring
PostPosted: Mon Feb 22, 2016 4:47 pm
Make love, not moderators
Has anyone had to source the o-ring that goes on the end of the coolant tube? It seals the tube to the back of the water pump housing..
Mine is starting to seep a bit.. I checked RockAuto but no luck, and Suzuki is no longer around here...
Let me know..
 Post subject: Re: Coolant tube o-ring
PostPosted: Mon Feb 22, 2016 5:14 pm
I just use the standard O-rings available at the hardware store. Make sure it fits tightly.
Haven't had any problems with them.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Tue Feb 23, 2016 10:03 am
http://www.ebay.ca/itm/Geo-Metro-Coolan ... lr&vxp=mtr
Engine Coolant Outlet Gasket Victor C31514
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Tue Feb 23, 2016 11:45 am
I just had this problem and I found one. The only place I could find that had thick enough o rings was home hardware, I just bought a couple different sizes because they're so cheap to see which works best.
___________________
89 Swift gti
PostPosted: Tue Feb 23, 2016 4:12 pm
Thanks guys, I grabbed that one from eBay..
cron
