It is currently Sat Feb 24, 2018 7:31 am
PostPosted: Thu Aug 18, 2016 11:20 am
Anyone know the length or have a wheel stud from a gt to measure? I need to know the length
Thanks!
___________________
89 Swift gti
PostPosted: Thu Aug 18, 2016 3:41 pm
19mm.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Thu Aug 18, 2016 4:34 pm
Is that the size of the knurl?
___________________
89 Swift gti
PostPosted: Fri Aug 19, 2016 6:01 am
(if your are looking for longer wheel studs, there is a stud from a subaru xv turbo that nearly fits (fits but slightly bigger knurl , harder to press fit... watch out...)
if not, sorry for thread polution :lol:
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
suprf1y's 200/335i - 210/340e camshaft
cusco 1way LSD
PostPosted: Fri Aug 19, 2016 6:26 am
19mm is the length from outside of the hub to outside of the stud. I'm not sure how to describe it. But it's the length that goes through the rim.
2003-EVO7 GT-A
