It is currently Wed Feb 21, 2018 6:40 pm
 Post subject: Vitara pistons ?
PostPosted: Tue Oct 11, 2016 8:44 pm
Will these work in a G13B with a 75MM overbore ? What would the compression ratio end up at ?
http://www.ebay.com/itm/191761498016?_t ... EBIDX%3AIT
Ken.............
 Post subject: Re: Vitara pistons ?
PostPosted: Tue Oct 11, 2016 10:30 pm
Poor choice even for a turbo application. Compression is too low
PostPosted: Tue Oct 11, 2016 11:24 pm
What would you recommend that don't cost an arm and a leg ? I do want to turbo but only 8-10 pounds.
Ken..........
PostPosted: Wed Oct 12, 2016 5:07 pm
Does it have to be 75mm? If 74.5 will do, then these (or equivalent)
http://www.ebay.ca/itm/GM-Car-1-3LSOHC- ... r4&vxp=mtr
Available in .020" oversize which is 74.5 mm
PostPosted: Wed Oct 12, 2016 8:38 pm
Ken.............
Depending on the dish of the piston, between 7.3-7.9:1. Pretty low.
viewtopic.php?t=24954
I've read somewhere people shaving the block 1mm to raise the compression while using vitara pistons. Because that's the distance the vitara pistons keep from reaching the top of the block.
2003-EVO7 GT-A
Aruba "one happy island".
