It is currently Sat Feb 24, 2018 4:35 am
 Post subject: aftermarket fusebox
PostPosted: Fri Apr 14, 2017 1:13 am
Look at the heavy fusebox... I thought to get the aftermarket fusebox... LP minifuse looks nice and lightweight... so is it advantage over regular fuse?
https://en.wikipedia.org/wiki/Fuse_(automotive)
 Post subject: Re: aftermarket fusebox
PostPosted: Fri Apr 14, 2017 7:56 am
more fuses/ circuits in a smaller area. they can be harder to pull out to check, I use needle nose pliers to pull them out to check them.
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Fri Apr 14, 2017 5:16 pm
I don't worry about that. I am going to do my own harness. I don't like how factory harness is.
I have another strategy to save my money so I will double check with width blade between female connector.
