It is currently Tue Jan 16, 2018 5:06 pm
Post new topic Reply to topic  [ 74 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed Apr 24, 2013 3:47 pm
UPDATED 31 July 13 10:40am
I have looked for a turbo for this car for 2 years with no luck and now decided to just part it out. The odometer shows 46,455 and there is no 100k place so I am just going to assume its 146,455 to be on the safe side. I bought the car 3 years ago drove it home with a thick white cloud following me. The car ran strong, no missing, shifted just fine, and the turbo spooled up and power kickedby in just like it should. The white smoke was the reason for the engine to be taken apart only to find out it was not the engine at all. The turbo had bad seals and caused oil to blow by. I looked for local shops to rebuild the turbo and cost is over $900 so I passed on that, and new turbo from Turbo supply just quoted $1152.56 for a new one. I decided its not the direction I want to go. Part out has been the last option to do but here it goes.
------Shipping is on you unless we come to an agreement----- note: I'm in Fort Worth, Texas 76112 area
I work FRIDAY, SATURDAY, & SUNDAY's so if I get slow in responding on those days thats why, all the rest of the days I am off work.
All prices are not set in stone and I am willing to work with you on getting them where we are both ok with it.
This is whats left in my garage ready to go, shipping on you so send me your zip code & I will get the quote.
price / description
10 -blower motor/ heater
30 -passenger side fender
25 -both door cards w/all plastic pins
30 -driver side front window
30 -driver side rear window w/latches and hardware
30 -pass side front window
30 -pass side rear windor w/latches and hardware
10 -4 seat belt assy.
5 -2 good rear hatch supports
10 -steering wheel
5 -rear view mirror w/rubber part that touched the windshield
5 -antenna assy.
5 -map light assy. (sits around rear view mirror)
45 -brake booster/ master cylinder
5 -radiator fan
5 -shifter boot
150 -engine block
10 -oil pump
5 -pick up tube
10 -valve cover
10 -pullies
5 -dip stick assy
5 -coil
50 -crank
10 -water pump
10 -intake piping
5 -charco can
15 -boost solenoid/ controller
20 -2x crank gear's
5 -oil filter tube
100 -ported head
10 -air filter assy
10 -oil pan
5 -water pump pipe (runs across the back of the motor)
Trashed:
-3 pedal assy.
-passenger side door, has left both window seals, inner/ outter door handles, latche, hinges
-driver's door, has left both window seals, inner/ outter door handles, latche, hinges
-rear hatch w/ defrost
-both sun visors
-shifter assy. w/boot knob and 2 bars that go to the trans
-floor carpet
-trim around back windows
-rear hatch speaker panel
-dash (all parts were removed)
-driver seat
-rear seats
-all interior plastic trim
This sold & shipped:
- A/C (compressor, damaged condenser, evaporator, lines, dryer, switch's)
- intake manifold w/TB
- starter
- distributor
- Injectors
- clutch, flywheel, pressure plate
- alternator
- electrical harness for engine and interior
- ignition switch assy. /2 keys, covers, & switches
- ECU
- a/c controls
- pistons + rods
- glove box door
- hood prop rod w/plastic holder & rubber part at bottom
- passenger seat
- exhaust manifold
- fan switch
- turbo elbow
- fuel rail w/regulator
- AFM
- motor mounts
- radiator
- roller shell w/clear texas title
- cracked windshield
- steering rack
- 5 wheels
- suspension
- gas tank w/half tank of old gas
- e-brake
- brake system minus the booster, & master cylinder
- speedometer + clear cover
- 2 pc. intercooler trim from hood and grill
- side skirts
- rear mud flaps
- side mouldings
- fender side markers
- 2 damaged mirrors
- 3rd tail light
- int. wiper switch.
- window handles
- tranny
- a/c controller
- both head light assy.
- front grill
- roof trim
- 3 rear trim pieces
- 3 hub caps
- both upper door trim
- gas door
- both tail lights
- both door pockets
- turbo
- cross-member
- intercooler w/black cover and bracket
1st I need to have you guys post here at least saying PM'd so others wont think you are jumping in front of them and maybe add what you pm'd about would help in sort who's asking for what 1st.
2nd 24hour hold on parts, from the time I give you a quote. I cant have my house cluttered with boxed parts ready to ship and no payment sent, + I have to keep my 2yr old daughter from trying to open them
Thanks Tony
PostPosted: Wed Apr 24, 2013 4:10 pm
let me know if you want a certain shot of something.
PostPosted: Thu Apr 25, 2013 12:54 am
Updated above
Thanks Tony
PostPosted: Thu Apr 25, 2013 12:24 pm
Updated above
Thanks Tony
PostPosted: Thu Apr 25, 2013 2:24 pm
I live in arizona. please call me sounds like you need a little help.Or send message via team swift.It does not cost1,300 for a new turbo. there trying to cheat you.certainly you can spend that on one but it is not needed.I can buy some parts from you but your selling them much to pricey they dont usually go for that theres more out there.why dont you just sell the whole car. please call 520-481-2795. or send message.
PostPosted: Thu Apr 25, 2013 9:25 pm
Updated above
Thanks Tony
PostPosted: Fri Apr 26, 2013 10:56 pm
PM at ya
Mike
Valley Grande, AL
1986 Sprint plus
Why do we do it?
PostPosted: Mon Apr 29, 2013 8:59 am
Updated above
Thanks Tony
PostPosted: Mon Apr 29, 2013 10:57 pm
Updated above
Thanks Tony
PostPosted: Tue Apr 30, 2013 11:06 pm
Updated above
Thanks Tony
PostPosted: Wed May 01, 2013 5:05 am
PM'd you.
Thx.
Sol
PostPosted: Fri May 03, 2013 8:44 am
Pm'd
Fuel Tank, Knuckles , Transmission
PostPosted: Fri May 03, 2013 11:38 pm
Updated above
Thanks Tony
PostPosted: Sat May 04, 2013 3:10 am
PMs sent- a/c unit and passenger seat pending
PostPosted: Sat May 04, 2013 6:23 pm
Give me a call. I spoke with you a few weeks ago.When you called me . I want to purchase the exhaust manifold. 1-520-481-2795
PostPosted: Sat May 04, 2013 9:42 pm
Updated above
Thanks Tony
PostPosted: Mon May 06, 2013 10:32 pm
Updated above
Thanks Tony
PostPosted: Tue May 07, 2013 12:28 pm
I am going through a lot of stuff to get a little box sent out of the USA and for a big box is just getting dumb on shipping cost and killing deals on parts. I will work with the last order today and after this if you are out of the USA I am sorry you will need a local shipping address to ship the parts to and have them send you the parts.
Thanks Tony
PostPosted: Tue May 07, 2013 12:33 pm
Pm sent about headlights and grill.
Mike
Valley Grande, AL
1986 Sprint plus
Why do we do it?
PostPosted: Tue May 07, 2013 8:50 pm
Pm'd back Thanks
PostPosted: Wed May 08, 2013 9:41 pm
Updated above
Thanks Tony
PostPosted: Thu May 09, 2013 4:24 pm
Updated above
Thanks Tony
PostPosted: Sun May 12, 2013 9:09 pm
Tony I forgot to tell you I need the intake manifold and all that it consists of throttle body fuel rail wireing and all injector system. please call or pm so I can send you the money.
PostPosted: Mon May 13, 2013 1:03 pm
Need to read: fuel rail already sold
Still have the intake, TB, injectors, and I recomend to get them cleaned and flow tested at a reputable shop of your choice.
PostPosted: Mon May 13, 2013 6:26 pm
updated above
