It is currently Thu Feb 22, 2018 2:46 am
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2  Next
PostPosted: Wed Aug 21, 2013 12:04 am
So I'm selling most of my spares to fund my project. Pictures speak better than words so here it goes...
1,2 - Red powder coated front Gti brake parts $10 each
3 - Front Gti caliper $20 (probably needs new cylinder seals)
4 - Mk2 left rear light SOLD
5 - mk2 right rear light SOLD (one of the bolt-holes is too big)
*or the set for SOLD
6 - Mk3 right rear light $15 (was hit/cracked a little)
7 - Mk3 left rear light $25
*or the set for $35
8 - Passenger-side power window plastic $10
9 - Alternator cover $10
10,12,13 - $5
11,17 - Driver-side door-latch $10 each
14 - $10 each SOLD
15 - Rear middle light $25
16 - Rear middle light $15 (bolt-holes too big)
18 - Driver-side window rail $5
19 - Windshield wiper motor $15
20 - Driver-side power window $25 (glass is broken)
21 - Driver-side door handle $5
22 - Steering rack & pinion with tie-rods $50
23,25,26 - 1.3L oilpump $15 each
24 - 1.6L oilpump $20 SOLD
27,28,29 $5
30 - intermediate shaft and bearing carrier $25 SOLD (bearing seems to be good)
31 - Front control arm bushing bracket $5
32 - Crankshaft keyway for SOHC models $10
33 - Rear strut-cover boots $5 pair
34 - 1.3L DOHC and SOHC cam gears $10 each
35 - Gti box crownwheel$10
36 - 1.3L SOHC camshaft $50 SOLD
37 - Stock Gti exhaust manifold $15
38 - Gti head in nice condition (recently removed from a great working engine) $200 SOLD
39 - Only some parts left: valve cover $25 SOLD and cams $40 SOLD
40 - Front gti shocks with cut springs $15 each Rear shocks $10 each
41 - Mk1? A/C compressor bracket $15
42 - Mk2/3 A/C compressor bracket $10
43 - A/C compressor $50 viewtopic.php?f=15&t=56668&p=431314#p431314
44 - Gti flywheel $20
45 - Front uncut Gti spring $15
46 - Rear uncut Gti spring $10
47 - Gti speedo sensor $10
48 - Main fuse-box with surrounding harness $15
49 - Gti knuckles $45 for both viewtopic.php?f=15&t=56854&p=425889#p425889
50 - Driver-side window rubber $5
51 - Rear spoiler $20 (was apparently ripped from hatch, needs new brackets glued down/fitted)
FuLL A/C system: viewtopic.php?f=15&t=56372&hilit=+system
More parts: viewtopic.php?f=15&t=54106/
All prices EXCLUDING shipping-costs. Open to offers if you buy a lot of stuff. Willing to trade for performance parts (just tell me what you have).
image_id: 22616
1993 Swift Gti
 Post subject: Re: SWIFT PARTS FOR SALE
PostPosted: Wed Aug 21, 2013 4:22 pm
can i have a quote for shipping to germantown ohio 45327 usa
interested in # 38 ,( good working head with cams included ? i would assume ... ) and did you happen to conduct a compression test on said engine before dismantling it ?
thanks
PostPosted: Wed Aug 21, 2013 5:10 pm
thanks
No, I did not perform a compression test. The head was removed from a 1.8L bottom-end that burned a bearing past red-line (no surprise) before ever making it to the track. I saw that engine running and who worked on it, so I can tell everything is just fine. I was going to do some head-work on it, but now I have different plans. If you want, I can pour fuel/kerosene or similar in the combustion-chambers to see if the valves are leaking just to be sure.
Anyway according to my scale it weights 21kg... that'll cost you $150 on shipping to anywhere in the States.
image_id: 22616
1993 Swift Gti
PostPosted: Wed Aug 21, 2013 8:44 pm
Shipping quote to Greer,SC 29651 On 4 and 5 please. Thank you
Cars and Harleys
PostPosted: Thu Aug 22, 2013 8:58 pm
pm sent
image_id: 22616
1993 Swift Gti
PostPosted: Thu Aug 22, 2013 9:07 pm
One of the heads (item No.39) is temporarily not for sale anymore, as it's condition is way better than I thought. The rust inside was only on the surface of the cams and lifters but nothing to be alarmed about. After spraying some penetrating oil everywhere, I was able to take out the lifters...none of them is stuck and the bores in the head are clean. I'll fully inspect and clean everything before coming with a final price. Sorry if someone was interested.
image_id: 22616
1993 Swift Gti
PostPosted: Sat Aug 24, 2013 12:57 am
Set of MK2 rear lights SOLD.
image_id: 22616
1993 Swift Gti
PostPosted: Wed Aug 28, 2013 11:14 pm
One head (No. 38) SOLD. I'm keeping the other one... the valve cover and cams are still for sale though (check first post for details).
image_id: 22616
1993 Swift Gti
PostPosted: Wed Aug 28, 2013 11:17 pm
Excited to Get my baby back on the road.. Thanks alot !! Will give feedback as you requested and will notify you if i need any more parts on this list.. (very possible)
1995 Geo Metro Hatchback **1.3L DOHC 16V Gti 94 Engine**
PostPosted: Wed Aug 28, 2013 11:22 pm
No problem mate, great doing business with you ;).
image_id: 22616
1993 Swift Gti
PostPosted: Wed Aug 28, 2013 11:44 pm
Great doing business with you too!! Hope you sell all the parts
PostPosted: Sun Sep 15, 2013 12:46 am
BUMP
image_id: 22616
1993 Swift Gti
PostPosted: Sun Sep 15, 2013 9:15 am
Thanks for taillights every thing was great.
Cars and Harleys
PostPosted: Sun Sep 15, 2013 9:42 am
No problem mate :wink:, good to know they found a good new home...
image_id: 22616
1993 Swift Gti
PostPosted: Wed Oct 02, 2013 9:52 am
BUMP
image_id: 22616
1993 Swift Gti
PostPosted: Wed Oct 02, 2013 10:59 am
U wouldn't happen to have a mk3 twincam valve cover? If so price with shipping to R1N 0T9?
PostPosted: Wed Oct 02, 2013 12:50 pm
You have a pm...
image_id: 22616
1993 Swift Gti
PostPosted: Sun Oct 06, 2013 5:54 pm
Valve cover SOLD...
image_id: 22616
1993 Swift Gti
PostPosted: Sun Oct 13, 2013 7:43 am
A few bits sold... first post updated.
image_id: 22616
1993 Swift Gti
PostPosted: Thu Oct 24, 2013 8:14 am
1.3L SOHC camshaft SOLD... first post updated.
image_id: 22616
1993 Swift Gti
PostPosted: Wed Oct 30, 2013 3:34 pm
@ssclown
Will number 37 the Stock GTI exhaust manifold fit on a 1998 Chevrolet metro 4 door sedan with a 4 cylinder 1.3 litre? If the answer is yes how much would it cost to mail it to Vancouver, B.C., Canada?
PostPosted: Wed Oct 30, 2013 7:11 pm
Do you have the twin-cam engine? If not, I don't think it'll fit...
image_id: 22616
1993 Swift Gti
PostPosted: Thu Nov 07, 2013 8:33 pm
@ssclown
No its not the twin cam its the regular type 1.3 litre. I bought this car about three weeks ago and I really like it but when I was looking at from behind I noticed what a tiny diameter the exhaust pipe was so at some point I'd like to lose the catalytic converter and put a larger diameter exhaust pipe on it and if that header fits I'd like to put it on too. How could I find out if that header you're selling fits? If it doesn't fit, how much cutting and welding do you think it would take to make it fit?
PostPosted: Thu Nov 07, 2013 9:12 pm
I really don't know man, I haven't heard of anyone doing that. I think the exhaust ports on the "regular" 1.3l are square, while the twin cam has round ports. Why don't you build you own headers from scratch?
If you want to take it all the way, aftermarket parts are hard to find for your motor, so I suggest you get a Gti or do a small boost set-up. Getting your engine to be competitive won't be cost-benefit effective, so keep that in mind before you spend too much cash on it :wink: .
image_id: 22616
1993 Swift Gti
PostPosted: Sat Nov 09, 2013 9:59 pm
@ssclown
Right now I've got so many Sprints, Forsas, Fireflies, Swifts, Geos, and Metros to get back on the road in bone stock factory configuration that I don't have the time to start fabricating headers. I have so many cars to fix that I'm now paying another teamswifter to fix some of them while I fix some too. At 15 bucks for the headers I just thought they'd be nice to have if they were a quick and easy bolt on upgrade to do if I ever get around to putting a bigger exhaust on the '98 metro 4 dr sdn, which is my daily driver right now.
