It is currently Tue Feb 20, 2018 6:45 am
PostPosted: Thu May 08, 2014 7:57 pm
Item Description:
CLEARING OUT ALL MY GTI PARTS. EVERYTHING I HAVE LEFT GTI RELATED HAS TO GO AS I AM GETTING OUT OF GTI PARTS ALTOGETHER.
EVERYTHING IS NEGOTIABLE. WHATS LEFT AFTER XMAS WILL BE TAKEN TO THE TIP.
Off the top of my head, I have numerous amounts of the following parts;
(all prices in Australian Dollars, postage not included in price).
engine mounts - $20 each or $50 per set of 3.
alternators - $50 each.
seat belts (fronts + rears) - $20 each/ $30 per pair/ $60 per set.
shifter mounts - $10 each.
clutch cables - $10 each.
speedo cables - $15 each.
GTi brake boosters + master cylinders - $20.
GTi fuel doors (no key - pop type) - $5 each.
GTi engine bay fuse boxes - $5 each.
MK3 GTi wiper/indicator stalks - $15 each.
GTi Rear demister / rear wiper buttons - $5 each.
GTi Driver power window switches - $40 each.
Mk3 GTi factory dash clocks - $10 each.
GTi dashboard dimmer switches - $5 each.
Standard GTi fuel pump + level gauge- $40.
working power window motors - $20 each / $30 pair.
Mk3 door trims good condition - $35.
Front side windows - $10 each / $15 pair.
Rear side pop out windows + latches - $20 each / $35 pair.
Mk3 bonnet in good condition + heat matting (maroon colour) - $40.
Ignition barrels + matching Key/s - $45.
Standard height shifters + mounts - $25.
Mk3 GTi (220km/h) cluster (fuel gauge ground on back burnt out) - $25.
GTi driver side power window motors - $35.
GTi passenger side power window motors - $30.
Mk3 Swift Extreme stock steering wheel - $25.
Heaps of other interior parts including air vents, roof lights, plastic trims etc..... Inbox or reply for more details and prices of other parts not listed.
Contact Details:
PM or Reply
email - breslinnick@live.com.au
PostPosted: Fri May 09, 2014 8:42 pm
Clusters mk2 or 3?
08 Civic Wife's car
PostPosted: Sat May 10, 2014 5:01 am
crnolic wrote:
Clusters mk2 or 3?
Mk3
PostPosted: Mon May 12, 2014 11:53 pm
FIRST PAGE UPDATED - MORE PARTS ADDED @ 13/5/14.
PostPosted: Wed Aug 13, 2014 7:52 pm
Updated 14/8/14
BUMP
PostPosted: Sun Aug 17, 2014 1:51 am
Would you have door locks with keys that match an ignition barrel?
PostPosted: Sun Aug 17, 2014 7:28 pm
Please
I need the steering wheel and the cat .
How much is shipment to NY.
USA .
Thanks
PostPosted: Thu Nov 05, 2015 2:14 am
CHECK PAGE 1 FOR PARTS
PostPosted: Fri Nov 06, 2015 6:25 pm
Got the steering wheel left??
PostPosted: Mon Dec 21, 2015 2:18 pm
Is the Mk3 extreme stock steering wheel still available?
PostPosted: Sat Nov 12, 2016 7:26 pm
I know it's a long shot but anything still available?
Black 1989 Swift GTi 5 speed
Dark blue 1994 Swift sedan 5 speed
Green 1993 xfi metro 5 speed
