It is currently Fri Feb 23, 2018 9:18 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
PostPosted: Fri Dec 18, 2015 8:43 pm
I think I'm caught up on pms again, let me know if I missed ya!
http://www.freewebs.com/rmp-motorsports/
PostPosted: Fri Dec 25, 2015 10:20 am
Check your PMs again. Probably just missed your check. Merry Christmas.
PostPosted: Tue Mar 01, 2016 6:14 pm
bump, still have lots!
PostPosted: Wed Mar 02, 2016 2:27 pm
[b]Basically rebuilt it, thought I had everything right, but once installed, it will only shift between 4th and 3rd, seems locked the other directions.[/b]
This should be an easy fix. There is a small triangle shaped cover near the bottom of this unit, held down with 3, 10mm headed bolts. Pull that cover. Under it you will find a small cast iron cap. Shaped like a larger thimble. Pull the 12mm bolt and turn it around to the opposite direction. You will have to pull the shift tower on top too, so that you can pull up the main shift lever. Then onces it bolted back together, try it before you seal it all up. I hope this helps.
PostPosted: Thu Mar 03, 2016 11:07 am
Rear caliper
PostPosted: Thu Mar 03, 2016 11:28 am
Do you have an updated list of the parts you still have?
PostPosted: Thu Mar 03, 2016 3:10 pm
I have both rear calipers, and the list is fairly current, but I do have tons not listed individually.
PostPosted: Thu Mar 03, 2016 9:33 pm
PM sent.
PostPosted: Fri Mar 04, 2016 4:04 pm
Chek your PM
PostPosted: Fri Mar 04, 2016 8:23 pm
Pm's all responded to,
PostPosted: Sat Mar 05, 2016 9:24 pm
Email sent
PostPosted: Tue Mar 08, 2016 11:03 pm
Still interested in that computer, if your willing to part with it.
PostPosted: Tue Mar 15, 2016 11:24 am
Need a vert drivers door 89-91. In Utah could possibly pick up.
PostPosted: Fri Mar 18, 2016 4:51 am
All caught up.
PostPosted: Thu May 05, 2016 3:18 am
Parts list updated, also have more that may still not be itemized, just ask!
PostPosted: Sat May 07, 2016 9:34 am
Interested in GT steering wheel and MAF sensor. Can you send me picture of the steering wheel. What condition is it in? Thanks.
PostPosted: Tue May 10, 2016 6:32 am
Pms responded to, please let me know if ya get them.
