It is currently Mon Feb 19, 2018 1:15 pm
PostPosted: Sat Feb 20, 2016 4:09 pm
2)Used Throttle Position sensor(tested good) $100
3)Wilwood Big Brake Brackets $150 As Seen Herehttp://redlinegti.com/forum/viewtopic.php?f=3&t=53365&hilit=+wilwood+brake
6)OEM Suzuki Wheel Covers for the 7 Spoke Rims $75 Full set of 4
All parts Payable via paypal
Located in Fort Madison Iowa
1993 Suzuki Swift GT bringing back from the dead.
PostPosted: Sun Feb 21, 2016 11:36 am
Do you have the rear caliper ??
PostPosted: Sun Feb 21, 2016 8:28 pm
PM sent on that intake
PostPosted: Sun Feb 21, 2016 9:12 pm
Sorry no rear calipers.
PostPosted: Wed Feb 24, 2016 5:28 pm
Ok thanks
PostPosted: Wed Feb 24, 2016 9:15 pm
Will that short shifter fit a 98? The thread you linked to didnt say it would or not, thanks.
Go Hawkeyes!
PostPosted: Wed Feb 24, 2016 9:23 pm
anyone?
___________________
89 Swift gti
PostPosted: Thu Feb 25, 2016 12:58 pm
I think they are the same
PostPosted: Thu Feb 25, 2016 2:44 pm
Ive been looking on here and geometroforums, no definate answer, but tempted to go for it anyway. Im definately interested in it, Ill keep checking. Thanks.
PostPosted: Fri Feb 26, 2016 1:53 pm
Shifter get sold? Checked around and it should work on my 98. If you have it still, Ill take it.
PostPosted: Fri Feb 26, 2016 3:06 pm
Sorry shifter was sold.
PostPosted: Fri Feb 26, 2016 3:14 pm
Ok, thanks.
PostPosted: Sun Feb 28, 2016 12:16 pm
Did you ever run the brackets with the Wilwood Big Brake calipers and Honda discs? I was looking at how to locate the right disc and the specification of the Wilwoods verse what the diameter of the Honda brackets. I will have to do some exploring on Redline.
PostPosted: Mon Feb 29, 2016 3:29 pm
do you have all 4 of those hubcaps? if so im interested
92 Swift GT , 94 Metro 4 door 376k miles , 87 Samurai G16A very modified
PostPosted: Wed Mar 02, 2016 5:10 pm
Sent you a pm. I do have all 4
PostPosted: Wed Mar 02, 2016 5:17 pm
Here are the rotors I was planning to use http://www.ebay.com/itm/EBC-Turbo-Grooved-Front-Vented-Sports-Brake-Discs-Rover-800-2-0-Vitesse-GD241-/121450307814?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c4700a0e6
Or I was going to have http://www.adamsrotors.com/ build a custom set.
PostPosted: Sat Mar 26, 2016 9:52 am
bump, not sold going on eBay (open to offers)
PostPosted: Sun Mar 27, 2016 7:58 pm
How much for wiring Manuel?
Cars and Harleys
PostPosted: Sun Mar 27, 2016 8:01 pm
Sorry wiring manual sold
Users browsing this forum: Kranky99, swifterthanu and 2 guests
