It is currently Tue Oct 17, 2017 2:44 pm
PostPosted: Tue Mar 15, 2016 12:17 pm
Brand new...
Low speed hub w/ syncros , part number 24400-63860 95.00
1st gear p/n 24311-60b00 75.00
2nd gear p/n 24321--60b00 65.00
Also have new 3rd, 4th, and 5th gears and hubs.....shift shafts, forks, end plates, and other hard to find parts new and used.
You can't rebuild a transmission the right way with just bearings, synchros, and seals. 8 out of 10 Transmissions are going to need a second gear and a low speed hub and probably five out of ten are going to need all the 5th gear hardware REPLACED.
PM me.
Shipped as shown from Harrisburg, PA USA
2001 Swift 4/5, 3.52 trans, AC, Power Steering, 16580r13s
1993 Mitsubishi Galant 2.0 16 valve auto
1990 Mitsubishi Eclipse GS 2nd Gen 2.4 DOHC 4G64 10.5:1 pistons, 2.25 catback, 160CHP
 Post subject: Re: FS:Low Speed hub
PostPosted: Wed Mar 16, 2016 5:17 am
I'm presuming thats not an OEM version as it would be 3 x the price? thats excellent value for the most important parts of a rebuild.
PostPosted: Wed Mar 16, 2016 10:03 am
PM sent.
F/S 3Tech economy cam
F/S 90 Metro hatch
F/S 89 Swift GTi body only
F/S 92 Tracker 2 dr rwd stock
PostPosted: Tue Aug 16, 2016 10:55 pm
UP, still available.
PostPosted: Sun Apr 09, 2017 8:07 am
Bump
PostPosted: Mon Apr 10, 2017 2:33 am
Look carefully, It looks like and old gear with a new synco hub welded on.
If they didn't head treat the gear and hub after welding, the metal will be soft.
Fainya
