It is currently Tue Oct 17, 2017 10:38 am
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
PostPosted: Sat Jul 02, 2016 11:53 pm
I owned this car for 6 years, then sold it to a local guy last year. He loved it and drove it for 15k more miles, but recently the rear driver side strut tower broke free from the body due to a terribly rusted wheel well. He relisted it for sale last week so I bought it back from him so I could part it out in its entirety instead of seeing it go to the junk yard & crushed in a few weeks.
Engine still runs well despite lower compression. As of 6/30/16, the compression numbers are 160/90/170. Over the last 1300 miles, the previous owner averaged 42.2 MPG. I'd like to sell the engine whole, but will consider parting it out including the XFi camshaft. XFi 3.79 transmission still shifts well with ~140k miles. The Turbine Tech brace has an indention where the catalytic converter rested against it, but doesn't affect the function.
I still have some rare, hard to find parts. All prices are best offer. Free shipping unless otherwise noted. PM me for my PayPal address. I will try to keep the parts list updated as much as possible and first post, first serve. If you don't see a part listed, please feel free to ask.
Also please keep in mind this will be parked in my front driveway, so I need to keep the wheels intact so it still looks driveable and so it can be easily towed away in the end. If you are local and want wheel related stuff, I'll need your old parts in exchange. I am located in Lansing, MI.
ACCESSORIES PARTS
Coroplast Grill Block - $5 + Shipping
Coroplast Rear Wheel Skirts - $10 + Shipping
Coroplast Partial Kammback - $10 + Shipping
[s]MPGuino - $45[/s] SOLD
OEM Jack - $6 + Shipping SOLD
OEM Lug Wrench - $3 + Shipping SOLD
1998 Chevrolet Metro Owner's Manual - $5
AXLES & DRIVE SHAFTS
CV Axle Shaft (Passenger) - $32 + Shipping
BRAKES
Brake Booster - $18 + Shipping SOLD
Brake Caliper (Passenger Side New) - $13 + Shipping SOLD
Brake Caliper Bracket - $8 + Shipping SOLD - Driver's Side
Brake Master Cylinder - $11 + Shipping SOLD
Brake Pad/Shoe (Brand New Pads) - $2 + Shipping SOLD - Driver's Side
Brake Reservoir - $6 + Shipping SOLD
Brake Rotor (Brand New) - $11 + Shipping SOLD 1
DASH/COWL
Air Bag, Single Bag - $40 + Shipping SOLD
Dash Trim Bezel - $6 + Shipping
Sunpro 2” Electrical Water Temperature Gauge with Pillar Pod Bezel - $30
Glove Box Complete - $9 + Shipping
Glove Box Latch - $4 + Shipping
Ignition Switch w/Key - $27 + Shipping SOLD
[s]Instrument Cluster with Tachometer[/s] - $70 SOLD
Windshield Wiper Arm Passenger - $7 + Shipping
Windshield Wiper Blade Passenger - $2 + Shipping
DOORS
[s]Complete Trunk Release Actuator[/s] - $40 SOLD
Door Complete Front - $75 (Local Pickup Only)
Door Handle - Inside - $4 + Shipping
Door Handle - Outside - $9 + Shipping
Door Hinge - $5 + Shipping
Door Latch - $11 + Shipping Passenger SOLD
Door Lock Cylinder - $2/ea + Shipping
Door Rubber - $2 + Shipping
Door Trim Pads (w/o Accessories) - $12 + Shipping
Door Black Pillar Trim Piece - $22 Shipped SOLD
[s]Driver’s Side Remote Mirror[/s] - $15 + Shipping SOLD
[s]Passenger Side Mirror Delete[/s] - $30 SOLD
Window Crank - $2 + Shipping SOLD
Window Regulator - $18 + Shipping
ELECTRICAL
Alternator - $33 + Shipping SOLD
Battery January, 2013 - $30 (Local Pickup Only)
Computer/Controller/Ecm - $24 + Shipping SOLD
ENGINE BOLT-ONS
Alternator Belt Tensioner (w/bracket) - $18 + Shipping SOLD
[s]MPG Sensitive Cruise Control Kit - $175[/s] $125 SOLD
Dipstick - $2 + Shipping
Dipstick Tube - $2 + Shipping
Dipstick W/ Tub - $3 + Shipping
Harmonic Balancer/Crank Pulley - $20 + Shipping SOLD
Oil Pump - $7 + Shipping
Pulley - $4 + Shipping
Starter - $33 + Shipping SOLD
Starter Solenoid - $5 + Shipping SOLD
ENGINE
3 Cylinder 1.0 Complete Engine w/XFi Camshaft (160/90/170) 298k miles - $220 OBO (Local Pickup Only)
[s]XFi Camshaft - $125[/s] $100 SOLD
Crank Shaft - $90 SOLD
Cylinder Head, (w/o Cam) - $39 + Shipping
Engine Block - $100 + Shipping
Oil Pan - $23 + Shipping SOLD
Piston & Rod Assembly - $12/ea + Shipping
Push Rod - $2/ea + Shipping
Timing Gear/Camshaft 60A +2* Sprocket - $25 SOLD
'92+ 1.0 Style Valve Cover - $58.99 SOLD
’89-’91 1.0 Style Valve Cover - $10 + Shipping
EXHAUST SYSTEM
Catalytic Convertor - $60 + Shipping SOLD
Exhaust Manifold Springs/Bolts - $18
FRONT END PARTS
Fender - $47 + Shipping
Headlamp Mount Bracket/bucket - $6 + Shipping SOLD
Hood - $58 (Local Pickup Only)
Hood Hinge - $6 + Shipping
Hood Latch - $7 + Shipping
Hood Prop - $4 + Shipping SOLD
FRONT SUSPENSION
Sway Bar/Stabilizer Bar - $17 + Shipping Front - SOLD
Sway Bar Link - $3 + Shipping
[s]Turbine Tech Front Lower Underbody Brace - $190[/s]$163.55 SOLD
FUEL SYSTEM
Fuel Injector - $11 + Shipping
GLASS
Glass Door - $22 + Shipping
Glass Hatch - $40 (Local Pickup Only)
Glass-Quarter - $17 (Local Pickup Only)
HEAT - A/C
[s]A/C Clutch[/s] - $15 SOLD
[s]A/C Compressor[/s] - $44 + Shipping SOLD
[s]A/C Condenser[/s] - $28 + Shipping SOLD
[s]A/C Dryer[/s] - $8 + Shipping SOLD
[s]A/C Evaporator Core[/s] - $18 + Shipping SOLD
[s]A/C Hose[/s] - $12 + Shipping SOLD
[s]A/C Button[/s] - $11 + Shipping SOLD
[s]Blower Switch[/s] - $17 + Shipping SOLD
Blower Motor - $18 + Shipping SOLD
[s]A/c Evaporator Core Housing[/s] - $24 SOLD
Heater Fan Resistor - $7 + Shipping
[s]HVAC Knobs[/s] - $1/each + Shipping SOLD
Hvac Housing Complete - $40 + Shipping
[s]Temperature Control - $30[/s] $17 + Shipping SOLD
IGNITION
Coil - $12 + Shipping
Distributor - $30 + Shipping SOLD
Spark Plug Wire - $1 each + Shipping SOLD
INTAKE
Air Intake Complete - $20 + Shipping
Air Intake Lid - $4 + Shipping
Air Filter K&N - $25 + Shipping SOLD
Air Intake Hose - $6 + Shipping
E.g.r. Valve - $7 + Shipping SOLD
EGR Vacuum Solenoid - $7 + Shipping SOLD
Intake Manifold - $45 + Shipping
Throttle Body W/O Injector - $29 + Shipping
Throttle Body W/Injector - $40 + Shipping
INTERIOR
Dodge Neon Armrest (has two small holes for toggle switches) - $15 + Shipping SOLD
[s]Clockspring - $24[/s] $12 + Shipping SOLD
Center Console - $15 + Shipping SOLD
Glove Box Door - $16 + Shipping
[s]Brake/Clutch Pedal Assembly[/s] - $60 SOLD
[s]Shifter Assembly[/s] - $28 SOLD
[s]Shifter Knob - $12[/s] $2 SOLD
[s]Sun Visor with Mirror - $16[/s] $10 SOLD
LIGHTS/LAMPS
Foglamp Pair - $6 + Shipping
Headlamp, Sealed-Beam Sylvania Xtravision (One Brand New) - $2ea + Shipping
High Mount Stop Lamp - $8 + Shipping
[s]Parking Lamp - $20[/s] 11x2 + Shipping SOLD
Tail Lamp - [s]$34[/s] $17 + Shipping Left Side SOLD
RADIATOR /ENG. COOLING
Radiator Dual Core - Copper - $35 + Shipping SOLD
Radiator Fan Assembly - $18 + Shipping
Radiator Fan Motor Only - $12 + Shipping
Radiator Fan Shroud - $15 + Shipping
Radiator Hose - $4 + Shipping SOLD
Thermostat Housing w/extra bung for aftermarket coolant temp. sensor - $30 + Shipping
Water Pump - $7+ Shipping
RADIO / AMPS
[s]Sony Xplod CDX-GT120 Radio Am/Fm/CD/AUX + wiring harness[/s] - $45 SOLD
[s]Speaker Grill[/s] - $5 SOLD
[s]Pioneer Speakers[/s] - $5 each + Shipping SOLD
REAR BODY PARTS
Hatch Shock Pair - $6 + Shipping SOLD
Hatch W/glass - $70 (Local Pickup Only)
Hatch W/o Accessories - $45 (Local Pickup Only)
[s]Trunk Latch[/s] - $18 SOLD
RELAYS/SWITCHES
[s]Dual Stalk Multifunction w/9 Position Intermi SOLD Wiper Switch[/s] - $40 SOLD
[s]Headlamp Switch[/s] - $19 SOLD
SEATS
Seat Belt (retractor) - $12 + Shipping Front SOLD
Seat Belt Buckle - $6 + Shipping Front SOLD
SENSORS
CTS & IAT Sensor Trickers - $50
[s]Idle Air Control Valve/motor - $9 + Shipping[/s] $13 SOLD
M.a.p. Sensor - $8 + Shipping
Misc. Sensor - $7 + Shipping
Oxygen Sensor - $5 + Shipping
Throttle Position Sensor - $7 + Shipping SOLD
TRANSMISSION & CLUTCH
3.79 XFi Transmission ~140k miles - $225 Shipped SOLD
Flywheel 1.0 - $22 + Shipping
Inspection Plate - $6 + Shipping SOLD
WHEELS/TIRES
Compact Spare Tire - $12 + Shipping SOLD
PostPosted: Mon Jul 11, 2016 10:36 pm
Quite a few parts have sold. Still have a lot left. All prices are best offer and all offers will be considered.
PostPosted: Wed Jul 27, 2016 10:43 pm
Driver’s Side Remote Mirror & Passenger Side Mirror Delete both sold along with the green coolant reservoir cap.
PostPosted: Thu Jul 28, 2016 11:07 pm
Have tried the metro forum? You would stand a better chance than the Swift enthusiast.
PostPosted: Fri Jul 29, 2016 4:45 am
Yep, I have it there, Metro Facebook groups, eBay & craigslist. I've moved quite a few parts. Thanks for the suggestion.
PostPosted: Fri Aug 19, 2016 9:44 pm
Latest items sold:
Rear wheel skirts
Driver's side brake caliper bracket
Black door pillar trim pieces
Hatch shocks
PostPosted: Tue Aug 23, 2016 10:24 am
K&N Air Filter sold.
PostPosted: Wed Aug 31, 2016 7:55 pm
Front Seat Belt Retractors & Buckles sold.
Passenger door latch and window crank have sold.
PostPosted: Mon Sep 05, 2016 10:29 pm
Dodge Neon Armrest has sold.
PostPosted: Sat Sep 10, 2016 4:17 pm
Starter and brake reservoir sold.
PostPosted: Sun Sep 11, 2016 9:18 pm
3.79 XFi Transmission sold.
PostPosted: Wed Sep 14, 2016 11:34 pm
Brake booster, radiator rubber/mounts & TPS sold.
PostPosted: Sat Sep 17, 2016 12:21 pm
Driver's side brake caliper + brand new pads are sold.
PostPosted: Wed Sep 21, 2016 9:45 am
Hood prop plastic inserts sold...still have the actual prop.
PostPosted: Sat Sep 24, 2016 9:23 pm
XFi camshaft sold.
PostPosted: Thu Sep 29, 2016 8:03 pm
eBay.com offers $15 off $60 when you apply coupon code CFLASHSAVE15NOW at checkout. Promotion is valid until 10pm PT today, September 29, 2016.
Check out my ebay listings if you'd like to save $15 on a $60+ purchase.
http://www.ebay.com/sch/mjspiess/m.html ... pg=&_from=
PostPosted: Mon Oct 03, 2016 10:53 pm
Ignition switch + key and ECM sold.
PostPosted: Wed Oct 19, 2016 11:36 pm
Blower motor sold.
PostPosted: Thu Oct 20, 2016 10:47 pm
Center console sold.
PostPosted: Sat Oct 22, 2016 12:56 pm
Window crank knob sold.
PostPosted: Sat Oct 29, 2016 11:37 pm
Spare tire, lug wrench, jack and head light bezels all sold.
PostPosted: Sun Oct 30, 2016 4:50 pm
Timing Gear/Camshaft 60A +2* Sprocket sold.
PostPosted: Mon Oct 31, 2016 9:03 pm
Rear bumper cover, passenger caliper, rotor, hood prop, down pipe with cat, master cylinder and alternator all sold.
PostPosted: Thu Nov 03, 2016 12:27 pm
PM Sent
PostPosted: Thu Nov 03, 2016 11:52 pm
1992Poddy wrote:
PM Sent
Replied.
