It is currently Sat Oct 21, 2017 4:36 pm
PostPosted: Tue Dec 13, 2016 3:29 pm
Help!
Also..maybe someone has higher final drive than original?
PostPosted: Thu Dec 15, 2016 8:58 am
See j63812f, http://geometroforum.com/index/ He has new gears to sell. What ratio do you have and it matters if its a 3 cly or 4 cly. The ring gear is thicker on the 4 cly units. I hope this helps.
PostPosted: Thu Dec 15, 2016 2:05 pm
Murf I suspect he is after proper gti gears which were in Gtis which were sold world wide except for North America
Standard & Gt, Gti 3,4,5 gears in red
3.417 41/12
1.895 36/19
1.280 32/25 1.375 33/24
0.914 32/35 1.030 34/33
0.758 25/33 0.871 27/31
Joel has a line on 2nd gears which are exactly the same between all gearsets.
PostPosted: Fri Dec 16, 2016 9:32 pm
Just send faniya a PM.
PostPosted: Sat Dec 17, 2016 1:28 am
Faniya has never ever seen proper gti gears let alone source them.
If you want a new standard 2nd gear then pm Joel / J63812f as Murf suggested.
If you want lower ratio final drives then PM fdgti, he last logged on in Sept viewtopic.php?t=54595
If you want the closer ratio gti gears then you need to try forums that are based in countries where they were sold like redlinegti.com an Australian forum, suzuki4u and uk-ssgti.com in the uk, there are suzuki forums in Portugal, Hungary and a Spanish one I think that may help.
If you have no luck then PM me, proper gti gears are extremely hard to find these days.
PostPosted: Fri Jan 20, 2017 8:30 am
Hi ! I have for sale MK2 89 - 96 GTi gearbox. Price includung shipping to Estonia 200eur. I can sale you final drive with custom ratio 4.9; 5.1 or 5.45 for 350eur if send together with gearbox or 380eur send only final drive.
nisor wrote:
Help!
PostPosted: Wed Jan 25, 2017 12:25 pm
thanks for the info Derek. :D
3.417 41/12
1.895 36/19
2001 Swift 4/5, 3.52 trans, AC, Power Steering, 16580r13s
1993 Mitsubishi Galant 2.0 16 valve auto
1990 Mitsubishi Eclipse GS 2nd Gen 2.4 DOHC 4G64 10.5:1 pistons, 2.25 catback, 160CHP
PostPosted: Sat Jan 28, 2017 2:05 pm
nisor wrote:
Help!
The other way 95+ 3cyl got the 4.39 final drive ... and 3-4-5 higher is in the swift gt or cultus gt all around the world exept in north america
