It is currently Tue Oct 17, 2017 2:33 pm
PostPosted: Mon Mar 06, 2017 7:03 pm
Upgrading my intake and will no longer need this. It's an intake off a '93 Swift GT with the throttle body included. As you can see from the pictures I have blanked off the coolant idle control mechanism. Also, there are additional vacuum ports that I had tapped and installed. It's a bit of a hack job, but it held the 16-18 PSI I threw at it. The "Electronic Fuel Injection Turbo" decal on top is a foil sticker that can be removed if not desired. (Jess might give you a hard time though :wink: ) The TPS sensor is not included. I will throw it in for an additional $10 USD but it does not have the standard connector on it, only individual wires. One note about the throttle body is that the top idle air bypass screw is seized and will not turn. I had other means of controlling idle airflow, so this wasn't a concern for me.
Summary -
Intake and Throttle Body $120 USD
TPS Sensor w/out connector $10 USD
Domestic US shipping is a flat $15USD. Item will be shipped from Wahoo, NE. Anywhere else will be actual shipping costs.
If there is no interest here I will post on eBay after a few days.
Dave
93' Suzuki Swift Gt Turbo
PostPosted: Mon Mar 06, 2017 7:13 pm
All I can see is ten boxes that say image in them. Not clickable for me.
Ken..........
PostPosted: Mon Mar 06, 2017 7:18 pm
Interesting, let me try to re-host the photos... Should be fixed now. Sorry about that.
